Author Topic: 1/32 Sopwith Tabloid, RNAS No. 168, Lt. Marix, Oct. 1914  (Read 50176 times)
« Reply #150 on: August 21, 2014, 12:24:21 PM »
Very nice to see you back at this unique Build, Bob. You are doing outstanding work on a true one of a kind project, and it's a pleasure and a learning experience to follow along!
« Reply #151 on: August 21, 2014, 12:25:55 PM »
Thanks Bo and Des!  That's high praise coming from two masters of the craft. ;D
Des, for those brackets I followed your lead from the Bataille and used 5 thou sheet styrene (.13 mm), with the holes punched with a Waldron tap and die set.  They were then cut to shape, bent as necessary and glued in place.  I am happy with the appearance, and I am sure they will look better after painting.
« Reply #152 on: August 21, 2014, 12:28:58 PM »
Thanks for the reply Bob, I had a feeling that you used the styrene sheet method but thought I had better check just in case you had come up with a new idea. I'm looking forward to seeing the next set of progress photos, this is turning into a real gem.
« Reply #153 on: August 21, 2014, 12:34:28 PM »
Des, I rely on you and Bo for new techniques!  ;)
« Reply #154 on: August 21, 2014, 12:54:53 PM »
Extraordinary work, Bob.  Really looking forward to seeing her under some paint.
« Reply #155 on: August 21, 2014, 01:57:21 PM »
A really interesting update, Bob. I admire you scratch builders and enjoy
following this build.  Well done!
« Reply #156 on: August 21, 2014, 06:23:59 PM »
Hi Bob,
 I'm pleased those naughty little 'Strippers'  made it across the pond in one strip!  ;D
Your  magic is crafting a super little Tabloid, Bob! Great stuff!!
Cheers, BvB
« Reply #157 on: August 22, 2014, 02:21:49 AM »
The amazing build continues. First class work which I am really enjoying following. Thanks for the latest update.
Offline Old Man
« Reply #158 on: August 22, 2014, 05:55:08 AM »
Great to see more progress on this, Sir!
Very much like that 'sheet jig' idea, and may pirate it at some point in future....
« Reply #159 on: August 23, 2014, 02:43:09 PM »
looks great bob, i like tabloids, they are an important and unique aircaft.
Offline Vickers
« Reply #160 on: August 23, 2014, 02:49:40 PM »
This Tabloid scratch build of yours is most impressive, Bob.  This one is truly showcasing your technical acumen and already looks marvelous.  Did you vacuform the upper cowling? The contours look perfect.
« Reply #161 on: August 23, 2014, 09:51:19 PM »
I'm going to have try the jig for the under carriage . What method did you use for the wings ?
« Reply #162 on: August 24, 2014, 02:20:32 AM »
Thanks folks!
I borrowed the undercarriage jig idea from Rick or Lance or someone here.  It's particularly helpful whenever the undercarriage does not have pre-made fitting holes in the fuselage. :o
Vickers: Yes, the upper cowling is vacuformed, along with the chin cowling (see earlier pages of this log for details).  It was a bit of a struggle, as the first basswood master did not produce a shape and fit I was happy with, so I made a second master and fiddled with it until I got an acceptable shape and fit over the styrene stringer fuselage frame.  It took about a half dozen pulls to get it right.  I am happy with the way it turned out.  The "fabric" portions of the fuselage are 10 thou styrene sheet over the styrene stringer frame with bulkheads.  I adapted techniques Des used in his Taube scratch build log.  Lots to be learned there! :D
Terri:  I borrowed the wing technique from Des, as described in his Bataille build log.  Two 1mm pieces of sheet styrene were cut in the shape of the wing then glued together in a lamination and immediately taped to a cylinder of appropriate camber/arc.  Des used an aerosol can, I used the wing bending jig I made for my Lloyd C.V scratch build, which jig I also borrowed from Des as described in his Voisin build log.  Allow the glue to cure overnight, and the airfoil shape will be permanent.  As you can tell by now, I owe much to Des for all of these techniques.  Thanks Des!
I am currently applying Von Buckles's 1mm vinyl strippers to the primed wings to make the ribs (yet another technique borrowed from Des in his Bleriot build log!).  I'm really just a copycat! ;)
I will post more pix soon. :D
« Reply #163 on: August 24, 2014, 04:24:50 AM »
Copycat or not Rob you are a master modeller and no mistake.
« Reply #164 on: August 24, 2014, 06:58:42 AM »
Thanks LM. :)  Here are some pics of the strippers being applied to the wings:
Once the strippers are all in place, I will use a few coats of auto primer to firmly affix them in place and fill in the edges.  I think this will look very much like the photos of the Hendon reproduction Tabloid.  CDL color will go over that.  More soon.
