Author Topic: 1/32 Sopwith Tabloid, RNAS No. 168, Lt. Marix, Oct. 1914  (Read 49897 times)
Offline Old Man
« Reply #120 on: June 07, 2014, 11:33:57 PM »
Excellent work, Sir!
A great project, too!
« Reply #121 on: June 08, 2014, 02:37:11 AM »
Working your magic with this one, Bob!
Excellent skills and perseverance  ;)
More!!!
vB
« Reply #122 on: June 08, 2014, 03:40:32 AM »
Really good modelling with that cowling. Moulding is a tricky process at the best of times, however it is done. You have done a tremendously good job there. Looking forward to seeing more of this construction.
Offline Vladimir Ziska
    • Nordland Models
« Reply #123 on: June 10, 2014, 07:04:05 AM »
Hello Bob,
breathtaking. I admire those who are able to create this. A fascinating and surreal.
Vladimir
« Reply #124 on: June 18, 2014, 08:44:28 PM »
Thanks for your kind comments everyone!  I have made some progress in the last two weeks.  The Cowlings are now in place, along with the aft portion of the fuselage sides:
The fuselage covering is ten thou sheet styrene, which will also be used for the metal side panels on the forward fuselage.  These will take a bit more work, as access panels and rivets (resin decals from Archer) must be added.
The cowling looks a bit sloppy now with the putty filler showing, but I think it will be fine once the metallic paint is applied, I hope.  ::)  Note that the engine cylinders do not protrude slightly below the chin cowling as shown on my plans.  This was probably the result of mounting the engine slightly too high on the firewall and cutting the arc of the cowl opening slightly too low.  Ahhh, close enough.  These early machines were hand built in small batches of one or two, so parts and details varied between aircraft (this is actually true in the case of the Tabloid).  That's my story, and I'm stickin' to it! ;D
I also neglected (forgot) to drill out cooling ports in the front top cowling.  Photos show that early models did not have these, others had varied size, number and location of ports, and there are no photos of No. 168 (she was left somewhere in Belgium after the Dusseldorf raid when Lt. Marix could not nurse his shot-up machine any further, and was never recovered as Marix made it back to Antwerp by train and lorry just in time to catch the last ship out with his withdrawing squadron).  However, the reproduction of No. 168 at Hendon has small ovoid horizontal ports on the top front cowling.  I have not yet decided whether to add these.  It would have been much easier to do before affixing the cowling.  I would hate to balls up the cowling now if I make a mistake! :o  Since this model is just a "look and feel" representation rather than a precise replica, I may just leave well enough alone.  We'll see.
I still have some details to add to the cowling joint.  After the front metal sides are in place, it's back to completing the wings! ;D
« Reply #125 on: June 18, 2014, 08:50:34 PM »
Amazing work, Bob. It is such a treat following a build of
someone with so much talent. Looking forward to the
next updates.
« Reply #126 on: June 18, 2014, 10:54:50 PM »
Stunning work Bob.
« Reply #127 on: June 18, 2014, 11:53:42 PM »
   Looking better with every update Bob. Those forward side panels with the details as you mention should really pull this one together. Great work and the results are showing it!
« Reply #128 on: June 19, 2014, 12:23:25 AM »
Your skillful work is paying off, Bob  ;)
Keep up the great work.
VB
« Reply #129 on: June 19, 2014, 12:50:42 AM »
Extraordinary work, Bob!  A true masterpiece in the works here.
« Reply #130 on: June 19, 2014, 04:51:03 AM »
Wonderful workmanship and truly great modelling. As you write, these machines were hand built and varied like the days of the week so small variations in detail probably do not matter too much and if no photos exist who can be sure? In any event if someone knows better let them make a better model than you. I defy them to!!!
« Reply #131 on: June 19, 2014, 06:52:08 AM »
I couldn't put it any better Bob, so I'll jump in and repeat Bud's comments!
« Reply #132 on: June 19, 2014, 11:04:45 AM »
I must agree with my Amigo! Just continuing to be both inspirational and amazing at the same time!
« Reply #133 on: June 20, 2014, 04:07:06 AM »
Just caught up on this one. Fantastic work, as stated by everyone else! That extra time spent getting the cowlings right has certainly paid off. Have you thought about using an empty beer can (or similar) for the metal forward panels - saves painting the aluminium inside, and it's very easy to work with, especially if you're making pretty much flat panels....
« Reply #134 on: June 20, 2014, 10:28:19 PM »
Truly remarkable craftsmanship so far !
