Author Topic: 1/32 Sopwith Tabloid, RNAS No. 168, Lt. Marix, Oct. 1914  (Read 50095 times)
« Reply #15 on: February 17, 2014, 01:27:03 PM »
You will also notice that the bottom wing has a corresponding gap as well. If you look at the following photo you will see that the wings are made up from sections, the top and bottom wings have a centre section and fitted to these are the outer wing sections. As far as dihedral goes, it appears that the top wing is level while the bottom wing has a very slight dihedral, similar to the Camel.
« Reply #16 on: February 17, 2014, 01:31:11 PM »
Thanks Des, I agree.  Just some further speculation based upon my drawings showing the flying wires entering the wings: is the dihedral shown in some drawings transient, based upon the wing warping control for this early aircraft?  Is this why the wing tips appear to be separate from the center section in the photos above, so that the wing tips lift up slightly as part of the wing warping?
Just some random thoughts.  Anyone know more about this?  Thanks.
« Reply #17 on: February 17, 2014, 01:36:33 PM »
Here is another photo which clearly shows the wing joint top and bottom.
« Reply #18 on: February 17, 2014, 02:15:44 PM »
Thanks Des!  That's a very helpful photo.  Do you have any more, or a link to the website where these can be found?
Offline Jim
« Reply #19 on: February 17, 2014, 08:02:49 PM »
Hi Bob - I took some photos of the Tabloid when I was in the UK over Xmas which I'll upload tonight. Hope these are useful to you. Regards Jim
Woof!
Offline Jim
« Reply #20 on: February 17, 2014, 08:36:52 PM »
Bob - photos are in the aircraft section. Look forward to seeing your build.
Woof!
« Reply #21 on: February 18, 2014, 03:48:34 AM »
Thanks again Jim!  These will be very helpful.  Much appreciated.  ;D
« Reply #22 on: February 18, 2014, 06:04:58 AM »
Hi Bob,
I have installed 24 images of the Tabloid on my website. The images can be found in Jim's post here: http://forum.ww1aircraftmodels.com/index.php?topic=3074.0
Good Luck!
vb
« Reply #23 on: February 18, 2014, 09:30:19 AM »
Thanks again Bob!  These will be extremely helpful.  :D
« Reply #24 on: February 28, 2014, 01:16:39 PM »
Okay folks, here we go!  I have enlarged my drawings to 1/32 and made templates for the parts to be cut from sheet styrene, i.e., the wings and tail planes.  The fuselage will be made by constructing a frame of 1mm (0.40) styrene strip to be covered with .25mm (0.10) styrene sheet.  The cowling will probably need to be vacuformed or push molded because it has vent holes than will have to be cut from the plastic.  A solid or built-up shape simply won't work.
I decided to start with the wings, and followed Des's technique of cutting out two 1mm sheet styrene "blanks" in the plan shape of the wings and gluing them together with Humbrol liquid cement and then clamping the wing into the airfoil jig overnight.  See Des's Caudron and Bleriot build logs on the main site for a full description.  Here are the parts cut out and glued together after an evening in the jig, with the top wing partly sanded and the bottom wing out of the jig but unsanded:
I will discuss details of the bottom wing when I begin working on it.  Once sanded to the correct taper, I will use Von Buckles strippers for rib tapes and spray with auto primer, again per Des.  Here is the sanding progress on the top wing, in cross section:
As Des has noted, this wing technique involves a lot of sanding.  I'll come up for air in a few days and let you see how they turned out.  Strippers are in the mail, and will arrive in about a week or so.  More later.
« Reply #25 on: February 28, 2014, 04:08:41 PM »
Brilliant start, Bob!  I'm really going to enjoy this one.
« Reply #26 on: February 28, 2014, 06:45:09 PM »
Good to see a start on this one Bob, the wings looked like they work out well for you, it is a very easy technique to make wings but they do require a bit of sanding. I knock the bulk of the material off with a really course paper first then finish off with fine, i find this gets the wing in shape real quick. Looking forward to seeing more progress Bob.
« Reply #27 on: February 28, 2014, 10:51:23 PM »
It was a wounderfull start, Bob.
« Reply #28 on: March 01, 2014, 12:01:38 AM »
Looking good Bob! These Scratch Built Projects are a joy to follow; there's just no limit to the subjects and this is no exception. "Keep on truckin"!! :) ;)
« Reply #29 on: March 01, 2014, 02:49:52 AM »
I agree with Lance, Bob.  I admire your talents and look forward to the rest of your build.
