Author Topic: WNW Pfalz DIIIa - Unknown MFJ  (Read 27390 times)
Re: WNW Pfalz DIIIa - Unknown MFJ
« Reply #105 on: February 19, 2014, 12:21:35 PM »
Hello Lance:
This is coming along nicely.  I like your weathering details, nicely done, and the prop, outstanding work.  I like the wire wheels, really add a nice touch and the overall appearance is really neat.  Looking forward to more updates.
« Reply #106 on: February 19, 2014, 12:38:26 PM »
Absolutely superb, Lance.  Your attention to detail is amazing, as usual. The wire
wheels look wonderful!  What kind of paint did you use on the tires?  Really inspiring
work, my friend!
« Reply #107 on: February 19, 2014, 01:05:40 PM »
Rick, Mark, Ernie,
   Thanks for the comments. Ernie, I sprayed the tires (Supplied black rubber "O" Rings) with Model Master Enamel, RLM 63 "Lichtgrau" semi gloss. The bottle was labelled December 2001 and was as good as new! I have a lot of paint like that from the days when time was at a premium and every return to the Hobby got overcome by events!
   And believe me, you Guys are correct about the spoked wheels, they are far more impressive when they are in your hands!
« Reply #108 on: February 25, 2014, 02:58:46 AM »
   Progress has been slowed by an attack of the Bubonic Plague, my wife of course insists it's a strain of influenza that many folks hereabouts have fallen victim to. Based on the way I've felt these past 4-5 days I'm sticking to my whimpering and whining assessment of it as a reincarnation of the flipping "Black Death"!
   The mounting of the top wing was a fairly simple exercise as the Kit engineering is fool proof in this regard. I used my normal scratched cabane alignment jig to ensure spacing and level installation using the Biplane Assembly Jig as basically a stand only. When the cabanes were cemented in place the inter plane struts were cemented into the lower wing points, the top spacing measured roughly from the cabane assembly C/L to provide the last critical placement. The upper wing was then popped onto the struts and the Radiator return line and extra thin CA flowed into the mounting holes. All went very smoothly and the alignment appears flawless.
    Some shots of the Cabane process........
   ..............and here's the upper in place and some of the rigging done. I'm trying to do the wing rigging a few components at a time, then painting it before the next set to reduce conflict and maximise access for the painting of the lines. I should really be waiting for my spool of the world's greatest rigging line from Steven Robson!
.......and last a shot showing the ongoing chipping of the lozenge incurred during handling for assembly and rigging; all which will require repair and/or touch up at the end. I predict I may be down to bare plastic by the time she's done! :'( The Anemometer is the Kit one, an absolute monster to get off the Sprues and assemble. The little cupped spinner component, the third utilised as the carpet beast gobbled two of them, or parts there of, is the challenge and I had to rob several from my DV / DVa Stash Kits)
   Today I hope to keep chipping away (pun intended!) at the rigging, other then a month of Lozenge repair I'm almost there!  >:(
« Reply #109 on: February 25, 2014, 04:47:20 AM »
Lance,
 You're doing great work on your P3a - She looks swell!  :)
Sorry to hear you haven't been feeling to good  :-[ Hope you spring back to full springiness real soon  ;)
Take care,
VB
« Reply #110 on: February 25, 2014, 04:52:35 AM »
Beautiful work Lance! Your wing mounting system is impressive. The lozenge and Silver as I have said, are a great combination.
The rigging looks great!!
« Reply #111 on: February 25, 2014, 05:04:25 AM »
She's looking very spiffy indeed, Rick!  ;D  Just outstanding work.  Chipping on the wings?  Just looks like dirt and stains to me.  ;)  Keep up the very fine work!
« Reply #112 on: February 25, 2014, 06:12:25 AM »
Thanks "Two-Bobs" and Rick. It's the old "I see it thus everyone else will for certain" thing rearing it's ugly head again! The white contrast of the chips is the center of my concerns however a little more patching and a quick and careful sealer coat should cure it. As for my cure, von B, if medication and rest don't perform any better soon I'll just increase my use of Dr. Macallan.......it's all not bad!  ;)
Offline drdave
« Reply #113 on: February 25, 2014, 07:20:45 AM »
What an amazing inspiration lance,
I absolutely love it, so mine is out of the box ready to go. Can't decide between Heldmans or an MFJ build. What yellow is that?
« Reply #114 on: February 25, 2014, 09:35:10 AM »
Dave,
  Thanks, it's been a very enjoyable Build with the exception of the Lozenge problems. It's a really well designed Kit, the engineering is superb and I know you'll enjoy it. The yellow is Model Master Enamel #33538 Insignia Yellow straight out of the jar. Heldmans' 4117/17 is a very colourful looking choice but many of the MFJ Schemes are very appealing too.
   Have fun with your Build; I'll be following your progress.
« Last Edit: February 25, 2014, 09:43:24 AM by lcarroll »
Offline IFF1418
« Reply #115 on: February 25, 2014, 05:06:04 PM »
Hi Lance,
That's a very well done progress. Still like your cabane struts jig and I will use it every time. You make the fixing of the upper wing seem easy, though it isn't really imho. And as Bob R. said, the chipping on the lozenge may well be weathering. I will wait quite a long time before applying lozenge, looks terribly difficult to me and out of reach for my limited skills. The rigging seems top up to now and I am looking forward what you will think of the rigging lines of Steven. Great work Lance!!
Kind regards
Patrick
Offline stefanbuss
« Reply #116 on: February 25, 2014, 05:48:55 PM »
Lance,
I missed news on your
Quote
cabane struts jig
somehow. Could you please explain how you made that?
Stefan
« Reply #117 on: February 26, 2014, 06:06:18 AM »
Lance,
Quote
cabane struts jig
Stefan
Stefan,
   Although I called it a jig it's really only a template. I carefully transfer the locations of the upper wing holes where the cabanes fit to a small piece of sheet styrene and dry fit the cabanes to the fuselage and then to that template. Once I'm happy with the fit and ensure the template is perfectly level (and set the angle of forward "sweep' if that's a factor) the cabanes receive a drop of thin CA in their fuselage joints. More CA can be added after the template is removed. On many types the upper wing can be added to the cabanes, then the interplane struts carefully inserted by bending the upper wing a tiny bit. In this case it was just as easy to add the interplane struts and verify their spacing from the Center Line. I use this technique on every build.
  Hope this answers your question.
« Reply #118 on: March 05, 2014, 09:33:13 AM »
    I finished her today, took a couple of quick Pictures on the work surface, and will try for some decent photos for Finished Models tomorrow.
Since the last update the rigging was completed, all Lozenge edge tapes added and sealed, several smaller bits such as the radiator return hose, Radiator shutter control handle, and flight control surfaces which were rigged as well. The landing gear was installed, bracing wires added, and finally a last hour of touch ups and final weathering was completed.
Final weathering included a lot of dirt and wear around the cockpit entrance route.............
   Love this little camera; the rudder has since been pushed back into proper position.
      and last, those magnificent wheels from down under, the Steven Robson 760's.
     More to follow tomorrow.
« Reply #119 on: March 05, 2014, 09:42:43 AM »
What a lovely Pfalz, Lance. I like every aspect of it, from the scheme, through the details, rigging, spoked wheels to the weathering. Top class!
