Author Topic: WnW Fokker E.1 (Early)  (Read 16651 times)
Offline Pete Nottingham
« on: December 13, 2013, 01:36:49 AM »
I've decided to go for a change this time to get me back in to the swing of things, I'm having a rest from Albies and Mercedes engines and going for Max Immelmann's Fokker E.1 (Early) Eindecker with a Taurus Oberursel U.0 engine, the kit has shipped from WnW, so we await its arrival.
Pete.
Re: WnW Fokker E.1 (Early)
« Reply #1 on: December 13, 2013, 01:55:12 AM »
Looking forward to watching it unfold...
« Reply #2 on: December 13, 2013, 02:08:11 AM »
Gonna give it a good try Bo.
Pete.
« Reply #3 on: December 13, 2013, 02:12:42 AM »
Can't wait to see how you bring those silky skills to this one.
« Reply #4 on: December 13, 2013, 02:27:52 AM »
Thanks Nigel, but I don't know where you get the 'silky skills' bit from, more like a rough old bit of sandpaper.
Pete.
« Reply #5 on: December 13, 2013, 04:08:56 AM »
Hello Pete:
Silky skills or Rough Sandpaper, either way, I am looking forward to your build log.  I am almost ready to do one, I keep getting distracted by the Fokker DVII's, DH9's and Snipes.   :o  I almost have the machining on the cowlings down.  Once I have that, I will start one.  Looking forward to seeing yours.
BEst
« Reply #6 on: December 13, 2013, 04:15:03 AM »
Look forward to seeing yours as well, good luck.
Pete.
« Reply #7 on: December 13, 2013, 03:23:44 PM »
I am also looking forward to your build!
Offline IvotB
« Reply #8 on: December 13, 2013, 07:10:17 PM »
Pete,
That´s nice. It will be the first WNW E.I here. So I am very anxious to see it coming alive here. You may need a cowl from Ron if you are fitting the Taurus engine (which is a stunning model, I have already recieved the kit from Lukasz). I understood that the WNW E.II and E.III cowl didn't fit over the Taurus U.I.
regards,
Ivo
« Reply #9 on: December 14, 2013, 12:49:23 AM »
Hi Ivo;
Thanks for the heads up on the cowl, but it seems Ron does an EIII cowl, is this the same as the cowl on the EI?
Pete.
Offline IvotB
« Reply #10 on: December 14, 2013, 12:52:26 AM »
No, it's not. I'm not absolutely sure though, so I'll have to check. The U.1 is a 9 cylinder version of the U.0, which is a 7 cylinder. The rest is thesame, so perhaps the cowl does fit. The E.IV cowl is definitly different, as the U.III has two rows of cylinders.
regards,
Ivo
« Reply #11 on: December 14, 2013, 12:55:46 AM »
Or you can thin it yourself  ;)
« Reply #12 on: December 14, 2013, 01:04:42 AM »
I think this could be a case of 'suck it and see', time will tell.
Cheers guys
Pete.
Offline Ian from Doncaster
« Reply #13 on: December 14, 2013, 02:05:36 AM »
Looking forward to this one Pete.
I really like the Eindekker and have the WNW E.I, EII/III early, and EIV in my stash.  Am considering a triple build but will definitely be following you I think...
« Reply #14 on: December 14, 2013, 03:22:20 AM »
Oh boy, the first E.I on the forum, no pressure then  :-\
Pete.
