Author Topic: 1/8 RAF Se 5a Hasegawa basis  (Read 86114 times)
Offline PROPELLER
Re: 1/8 RAF Se 5a Hasegawa basis
« Reply #180 on: January 31, 2014, 04:58:28 AM »
Thanks gentlemen for your kind words...
Finally some Hasegawa pieces!
For the fuselage:
Each of them need some fastidious work, a beginning..
Very massive all have been recut...
Before:
After:
Thanks for your support!
Dan.
Offline Beto
« Reply #181 on: January 31, 2014, 05:47:28 AM »
Sincerely, I woul not call what you have done "using the Hasegawa pieces". You only used the wood provided in the kit to make your own - and of course much better - parts. Greetings again!!!!
Offline PROPELLER
« Reply #182 on: February 06, 2014, 08:45:50 PM »
Hi gentlemen!
Tail plane in progress:
Immediately, it is clear that we will have somewhat refine it all ...
To the right  the original part,  tough!
The butt joints are not really mechanical, I realize systematically
 mid-wood assemblies:
A trailing edge rather "tough" too:
Once reworked, we arrive at an acceptable result:
Aileron hinges are "home made" of course!
As the rods besides, here is only the upper position:
As you can see, this beautiful kit requires a little work ...
The next stage will be mounting these on the fuselage and wiring.
Some sport, finally!
Dan.
« Reply #183 on: February 06, 2014, 09:02:30 PM »
Excellent reworking of the tail plane Dan, and the fuselage stringers look great.
« Reply #184 on: February 07, 2014, 02:26:56 AM »
A beautiful example of Modeling way above my level! Between you and Bo I am considering starting a new website, Knitting for ex Model Builders  ;D You can even use your Easy Line intended for rigging  8)
Offline IFF1418
« Reply #185 on: February 07, 2014, 05:39:30 PM »
Can I be your first member Rick? This build is unbelievable. A joy from the beginning on. Congrats again Dan!
Kind regards
Patrck
« Reply #186 on: February 08, 2014, 01:34:44 AM »
   I'm of the same mind, "RAGs". This is Modelling of a whole new standard! Would you consider a Quilting sub Chapter, my wife has lots of spare material??? :-\
« Reply #187 on: February 10, 2014, 12:26:46 AM »
I keep thinking Im going to glimps the hangar interior in the background revealing this is a full sized bird your building!!!
Offline PROPELLER
« Reply #188 on: February 10, 2014, 03:17:18 AM »
Thank you very much guys!
No secret in fact... Six or seven hours per day in my work shop, well equipped and a bit of patience!
Who said rigging, and wiring may be?
Port aileron is rigging and wiring!
To prevent rigging trouble...
To prevent wiring trouble too...
Pulleys and supports, height for ailerons...
Chers, Dan.
« Reply #189 on: February 10, 2014, 04:49:51 AM »
Wow.
« Reply #190 on: February 12, 2014, 01:37:47 AM »
Hello Dan:
Just catching up a bit here.  It is neat to see modeling at this level.  It is really a throw back to modeling in the early days when plans and raw materials were all that were in the box.  This is turning out really nice and displays your outstanding workmanship and attention to detail.
Offline PROPELLER
« Reply #191 on: February 12, 2014, 02:06:21 AM »
Thank you Bo and Mark!
Once upon a time wires. A lot of wires...
Now, here they are, all:
To be honest, it's a bit boring.
For a first attempt, I did not choose the easier way...
Cheers, Dan.
« Reply #192 on: February 12, 2014, 02:09:48 AM »
Dan,
I really don't know what to say other than incredible work!
Offline Carpo
    • A gallery of my Models
« Reply #193 on: February 12, 2014, 04:15:35 PM »
Inspirational job - I have the Camel in my stash awaiting my retirement (15 years to go)
You should publish a book on this build!
Carpo
The air force will always need technicians because pilots need heroes too.
Offline IFF1418
« Reply #194 on: February 12, 2014, 06:37:36 PM »
Hi Dan,
Incredible. I am speechless.
Kind regards
Patrick
