Author Topic: 1/8 RAF Se 5a Hasegawa basis  (Read 85625 times)
Offline xmald
Re: 1/8 RAF Se 5a Hasegawa basis
« Reply #105 on: December 13, 2013, 08:22:09 PM »
It is really hard to write something original. This is fabulous!
Best regards
Filip
Offline PROPELLER
« Reply #106 on: December 14, 2013, 04:03:36 AM »
Thanks guys!
To Jaceck, no rods in my engine too..
Thank you very much Albatros, but an answer call an other question:
Post war too?:
Well, today main fuel tank.
Not finished, but what a struggle!
First step, easy...
Two "hard" lips to accept some aggression:
 0,3mm brass  sheet annealed, and then all shots are allowed!
To be honest it's hard!
But "impossible" is not french...
Wait and see.
Dan.
Offline PROPELLER
« Reply #107 on: December 14, 2013, 04:25:49 AM »
After the tank struggle, now a special post to Lindsay and may be for others...
My worksop! I know, i'm a lucky modeler.
But nothing really impressive:
Close up on the mill, chinese one:
And on the lathe, an old Emco 3, made in Austria!
You are welcome Lindsay!
Dan.
« Reply #108 on: December 14, 2013, 01:11:03 PM »
  Dan,
Now that's one outstanding workshop and very well equipped too. Very luck fellow in deed. No doubt in my mind you've certainly have the skills and craftsmanship needed to put all the equipment to their maximum use. Well Done my friend.
Offline Pete Nottingham
« Reply #109 on: December 14, 2013, 08:36:06 PM »
Awesome work Dan, a brilliant model.
Pete.
« Reply #110 on: December 15, 2013, 01:07:55 AM »
Very nicely equipped workshop, Dan.  The combination of that and your
amazing talents is nothing short of magic!
 Looking forward to the next update on the Se5.
Offline PROPELLER
« Reply #111 on: December 15, 2013, 03:45:09 AM »
Thanks gentlemen!
Without equipment, scratch building would become a nightmare!
Fuel tank, more but not the end.
But ends!
Nice game, the ends are not vertical!
Ok...
Another way to form :
Not so bad...
I forgot... Why brass for this one? Because lot of welding to come and it will be painted!
Have a nice WE!
Cheers, Dan.
Offline LindsayT
« Reply #112 on: December 15, 2013, 03:47:01 AM »
Thank you very much, Dan. You're right, nothing fancy, but well set up nonetheless. I expected to see a door marked "Lockheed" given the work that goes on in there.
Keep turning out the incredible work!
Lindsay
« Reply #113 on: December 15, 2013, 08:41:52 AM »
Lovely job on the fuel tank Dan, some intricate shaping need there. Very nice set-up in your workshop as well, all the tools and equipment you need to pull off such wonderful work.
« Reply #114 on: December 15, 2013, 09:49:00 AM »
Offline Zabu
« Reply #115 on: December 15, 2013, 08:14:42 PM »
 :o I'm completely blown away .
Awesome.
Offline PROPELLER
« Reply #116 on: December 17, 2013, 03:11:12 AM »
Thanks gents!
Today, tank more and no, it's not complete!
More technical pics, on the second end:
Cheers, Dan.
Offline PROPELLER
« Reply #117 on: December 21, 2013, 03:10:27 AM »
Tank is finished!
Some of you must be wondering where is the logic in this WIP ...
There is one. I remind you that Mr. Hasegawa in the box " Museum Series" has shown only the outside ... No engine , no fuel tank, only drawn on a fine aluminum sheet (the skin). So I can not avail myself of the pieces provided.
A photo will be more explicit , a beautiful montage " OOB " on ScaleMotorcars by MOUPPE  :
So I have to adjust everything with my items ... The tank will be the base.
I hope I made ​​myself understood ...
Dan.
« Reply #118 on: December 21, 2013, 11:31:45 AM »
Your work on this one continues to be beyond my comprehension! A True Work of Art! What a difference from the OOB kit!
Offline PROPELLER
« Reply #119 on: December 22, 2013, 03:28:24 AM »
Thanks RAGIII!
Today, stamping, on the mill...
Why? May be for a VICKERS 303...
In front, you can recognize:
Not so bad...
Dan.
