Author Topic: 1/48 Revell (Eduard) Bristol F.2B Fighter  (Read 15250 times)
Re: 1/48 Revell (Eduard) Bristol F.2B Fighter
« Reply #15 on: November 14, 2013, 06:38:54 AM »
You have done a great job with the interior Ro, the wood looks excellent.
Offline Cimmerian
« Reply #16 on: November 14, 2013, 07:36:45 AM »
Very nice interior. Looking really good.
Regards, Ken
Offline Zabu
« Reply #17 on: November 14, 2013, 08:04:07 AM »
Very nice looking interior for sure.
« Reply #18 on: November 14, 2013, 09:17:33 AM »
Great job of the interior, Ro.  This is going to be an amazing model.
« Reply #19 on: November 14, 2013, 04:15:05 PM »
nice work so far on your brisfit. this is a really good kit. it is sorta the same analogy of the eduard vs roden fokker d.vii. the eduard is nicely detailed and easier to build. the bottom wing is easy compared to roden as roden has all individual parts that dont lock in like the eduard. but the roden has much more detail in the engine/engine compartment area. good luck on your build and i will come watch now and then.
Offline IFF1418
« Reply #20 on: November 14, 2013, 05:10:50 PM »
Hi Ro,
Very fine interior. You are up to a great model!
Kind regards
Patrick
« Reply #21 on: November 14, 2013, 07:25:49 PM »
Hello Ro
As you are making this excellent progress you are fast approaching what for me was one of the key areas of construction: attaching the lower wing to the fuselage. As Albatros has said, the relevant Eduard parts click very nicely and securely into place. However, you may need to watch the undercarriage struts in relation to the lower wing. It is definitely nothing major, just some judicious sanding. I needed to file a little groove in the rear of the front struts and also very slightly enlarge the holes where the rear struts pass through the wing. As ever, lots of dry-fitting is the key.
« Reply #22 on: November 14, 2013, 10:55:41 PM »
Your interior looks fantastic! The wood framing is excellent.
Offline KONG
  • A day without sunshine is like...night
« Reply #23 on: November 15, 2013, 06:48:01 AM »
That is VERY neat  ;) Love it . . . Good work man  8)
All the best
DAVE
"If I could only have brought him down alive..."
Offline aviator01
« Reply #24 on: November 15, 2013, 07:36:11 AM »
Hi there,
thank you all for the positive comments, this means a lot to me. Today I joined the fuselage halves, was a little bit fiddly as there were inside a lot of parts which had to be carefully aligned. Then the fit was very good, still have to take care about the seam lines. Pics will follow, to much work at the moment …
@Nigel: Thank you so much for the tips and hints about attaching the lower wing and the fuselage. I will take care and do a lot of dry-fitting.
Cheers, ro
On the bench: 1/48 Revell (Eduard) Bristol F.2B Fighter
Offline aviator01
« Reply #25 on: November 20, 2013, 06:50:27 AM »
Hi to all,
just a quick update. The fuselage halves are glued together followed by some sanding. Next were attaching the struts to the underwing. Today I started drilling all the holes in the fuselage and wings. I couldn't resist to try the decals supplied by Revell's re-boxing. With some Micro Sol and Set they performed very nice. Yes, it's only slow progress …
Kind regards,
ro
Offline aviator01
« Reply #26 on: December 15, 2013, 07:12:48 AM »
Hi to all,
I moved forward with the build of my F.2B, but very slowly. Painting was done with Tamiya acrylics and my trusty H&S airbrush. Followed by a coat of Klear I started decaling the fuselage. Thank you for stopping by,
Kind regards, ro
« Reply #27 on: December 15, 2013, 07:34:46 AM »
Beautiful job with your painting and decal application, your shading looks superb, extremely well done Ro.
« Reply #28 on: December 15, 2013, 08:29:40 AM »
My thoughts, exactly, Ro!  Brilliant.
Offline Cimmerian
« Reply #29 on: December 15, 2013, 10:49:00 AM »
That's looking really nice. I'm wanting one of these more and more.
Regards, Ken
