Author Topic: Sopwith Type 806 Gunbus  (Read 13294 times)
Re: Sopwith Type 806 Gunbus
« Reply #30 on: December 08, 2013, 05:16:28 AM »
Brilliant work, LM!  Incredible workmanship on an unusual and interesting subject.
« Reply #31 on: December 08, 2013, 07:46:27 AM »
Thanks again to all of you for your compliments. Pushers really are not so difficult once a couple of problems have been solved, although each one has its own tricky part to get around - in this case it was the stagger of the struts, but in the end it was not nearly as difficult as I had imagined.
It's a surprisingly big beast isn't it?
The span of the model is approximately 8.5 inches (21 cm), compared with the FE 2 which is 7.75 inches (19.5 cm): it is why two sets of wings from other models have to be used because there are no kits available with wings of comparable span and chord. The Sopwith Gunbus will be the largest pusher model I will have made when it is finished - it will dwarf the FE 8! (5.25 inches - 17cm).
« Reply #32 on: December 13, 2013, 03:09:24 AM »
Evening All,
     I cut the undercarriage struts from card and shaped them to aerofoil section; the skids were from the same material. Small holes were drilled in the top of the skids where the struts fitted. I cut an axle from wire. I glued the axle to the skids and the cemented the struts into the tops of the skids. The struts angle inwards towards the nacelle, with the front ones vertical in relation to the skid and the rear ones angled forwards. While the struts were still soft I lowered the undercarriage unit so that the ends of the struts are inserted into the correct holes under the wings and nacelle. I could then adjust the struts and skids so that the struts are at the correct angles and the skids are parallel with the bottom of the fuselage. All of the struts and undercarriage units can now be painted and the rigging will follow.
Thanks for looking.
« Last Edit: July 04, 2017, 06:54:15 PM by lone modeller »
« Reply #33 on: December 13, 2013, 07:30:49 AM »
She looks great with all the struts and the undercarriage on, starting to look the real deal now, very well done so far.
« Reply #34 on: December 13, 2013, 08:29:42 AM »
  Lone Modeler,
Wow she's shaping up to outstanding old bus. Excellent struts and undercarriage my friend.
Offline IFF1418
« Reply #35 on: December 13, 2013, 11:38:26 PM »
Hello LM,
It's a beauty and an interesting model. Very very clean build and painting. Great work!
Kind regards
Patrick
Offline Zabu
« Reply #36 on: December 14, 2013, 07:02:11 AM »
It's coming along very nicely LM. The painting and scratched parts excels your skills.
Great work.
« Reply #37 on: December 14, 2013, 07:18:36 AM »
Nice progress, LM.  She looks good with the struts in place.
« Reply #38 on: December 14, 2013, 02:41:32 PM »
Great looking model! She has certainly taken on a whole new look with the struts, wings, and gear in place! Very Neat and Clean, OUTSTANDING!
« Reply #39 on: December 15, 2013, 05:28:40 AM »
Dittos to my amigos comments !
« Reply #40 on: January 03, 2014, 09:34:09 PM »
 Evening All,
   I have finished the Gunbus at last - there were about 140 individual wires to be put on to this model - more than any other that I have made, and compared with just over 50 on the DH 4, so this took quite a time.  The holiday break also helped to slow things down. I used 44 swg rolled copper wire for the rigging as trying to drill holes and rig with thread would not have been practical for me. In addition there are control wires which would be very difficult to attach. The tail skid and wing skids (the latter made from 5 amp fuse wire) were added after the rigging was finished and the model was complete.
I have posted more pictures in the completed models section if anyone is interested.
Thanks for looking.
« Last Edit: July 04, 2017, 06:56:58 PM by lone modeller »
« Reply #41 on: January 03, 2014, 11:32:36 PM »
Terrific LM! Well done. It's so nice to see one of the more rarely modelled aircraft done to such good effect.
« Reply #42 on: January 04, 2014, 02:36:42 AM »
Congratulations, LM!  Brilliant scratchbuilding of an extraordinary subject.  Heading over to finished models to check it out.
« Reply #43 on: January 04, 2014, 07:57:46 AM »
Well done LM, I will now slip over to the completed models board and check out your finished model, it looks superb.
« Reply #44 on: January 04, 2014, 11:34:31 AM »
Congratulations on finishing this one so well! I'll have to take a look at the rest of the pics...
