Author Topic: nungesser's nieuport roden 1/32  (Read 21616 times)
Re: nungesser's nieuport roden 1/32
« Reply #30 on: November 04, 2013, 02:08:00 AM »
Brilliant work on the cockpit, Paulo!  I like the anvil, too.  Looks like it would be very useful.
Offline Epeeman
« Reply #31 on: November 04, 2013, 07:09:51 AM »
Excellent work and progress, Paolo -
Your cockpit and engine are spot on.
« Reply #32 on: November 04, 2013, 06:36:36 PM »
Your Nieuport is progressing beautifully, Paolo.  I'm anxious to see
more as you go along.
« Reply #33 on: November 04, 2013, 11:24:24 PM »
Paolo,
Beautiful work - the prop looks amazing  ;)
Keep up the great work.
Offline mc65
« Reply #34 on: November 05, 2013, 10:41:32 AM »
really, you're too kind...
in spite of the friend to whom I am building this kit has asked me to do it out of the box, I can not leave everything as it is, quite simply.
I needed the precise dimensions of lewis to close the fuselage, so I could not do anything but replace the original one with one of tom's modelworks:
8270
after cooking on the fire the cooling jacket I rolled up on a drill bit, and prepared for some welding. quite easy.
8233
as a barrel, and reference to assemble straight all the parts (21, at the end) I used a needle from external 0.5:
8230
and here we are, now I have all dimensions I need to close the cowling top.
8251
the conveyor belt is straight from the box... apart from that you see its quality, I wonder from where the belt came out!
8252
8254
if the belt has no positive location, from under the gun comes out a pipe that flows here ... but what's the use?!?
8256
and now, before falling in love with the object in natural brass, a nice coat of primer...
8269
ok, there is something to touch up, but already it is better than the one from the box, I would say, even if it lacks the longitudinal ribs...
8267
and here the objective of the session, close the front part of the fuselage .. really small, uh??
8278
bye bye, p. ;)
« Reply #35 on: November 05, 2013, 04:57:22 PM »
Amazing work on the gun, Paolo! Your attention to detail is great.
I am enjoying the build more all the time.
Offline IFF1418
« Reply #36 on: November 05, 2013, 05:22:38 PM »
This is high class medeling Paolo. Your details are so good! Lovely.
Kind regazrds
Patrick
« Reply #37 on: November 06, 2013, 02:48:14 AM »
The Vickers looks fantastic, Paulo!  It adds even more visual interest to an already excellent model.
« Reply #38 on: November 06, 2013, 09:45:30 AM »
What he said plus!
Offline mc65
« Reply #39 on: November 07, 2013, 10:59:07 AM »
thank you!
one step or two ahead... holed all around to accept brass pins,
8294
so it sounds pretty sturdy, and allows the repositioning of the control surfaces to a more relaxed attitude..
8289
a quick dry fit,
8288
and glued the lower wing.
8292
then primer all around,
8332
and some alclad to the front cowling.
8337
and some trials on paper...
8336
what I would achieve it's a canvas painted in silver, not a metallic finish. it seems that a preshading will help, but neither alclad nor vallejo steel seems the right stuff, to me... I think something more whitish should work... any ideas?
cheers, p. ;)
« Reply #40 on: November 07, 2013, 11:20:13 AM »
  Paolo,
Great update my friend. She's shaping up to be one beautiful project. What shade of Alcad have you tried? I like the white aluminum shade for painted fabric areas on my projects finished in natural metal . If you can find it the Floquil "Old Silver" also works very well too. Keep up the outstanding work !
« Reply #41 on: November 07, 2013, 01:57:01 PM »
Wow! Great update!! I would go with a flat Aluminum with a minimal addition of grey mixed in. For fabric I used to add grey even to Floquil Old Silver. JMHO,
« Reply #42 on: November 07, 2013, 08:54:26 PM »
Paolo, for the fabric areas, I think I would go with Alclad Flat Aluminum
or White Aluminum. In the meantime, you are doing a wonderful job
on the Nieuport!
Ernie
« Reply #43 on: November 07, 2013, 09:10:30 PM »
Excellent updates Paolo and you did a brilliant job on the machine gun.
« Reply #44 on: November 07, 2013, 11:16:15 PM »
Great work Paolo!  You've made it look much easier than I know it is with this kit, and easier than my Ni.27 was!  ;)  Very well done my friend!  I look forward to seeing her in full plumage.  :D
