Author Topic: Friedrichshafen FF49B (Top Gun, 1/72)  (Read 21147 times)
Re: Friedrichshafen FF49B (Top Gun, 1/72)
« Reply #45 on: November 20, 2013, 01:16:30 AM »
Przemol,
   Once again I am amazed at the exceptionally fine quality of work you 1:72 Modellers produce. Very nice work on a very unique aircraft subject. You are doing wonders with this very basic Kit, looking forward to the finished product.
Offline Adam
« Reply #46 on: November 20, 2013, 09:51:38 PM »
Beautiful!
I'm looking forward photos of the finished model.
Adam.
Online PrzemoL
« Reply #47 on: December 01, 2013, 08:01:19 AM »
Thank you, everybody. Your kind words are indeed an encouragement I need more and more to complete this build. It is going sooo slow but luckily, all the time forward. Recently I have completed the shading of the upper sides of lower wings, prepared the upper wing to the assembly and finally got to the interplane struts. Right now the four outermost ones are glued and the glue is setting. To get them in proper geometry I have put the model back to the jig which had to be trimmed at some spots to accomodate for the floats. Then I set them in a proper layout and fixed temporarily using Patafix. When I got sure, they were right, I removed one at a time and glued with plastic glue controlling its position with respect to the other ones. When I got it right, I added a drop or two of liquid CA glue to fix it steadily. The front ones went first, one after another, then the rear ones. Tommorow I may dare to continue, probably with the innermost ones. The mid span and the cabane ones will go there only with the top wing sitting on. At least such is the plan...
PS. All the struts got the pins attached at their tips beore any assembly started. You may just see them on the top ends in the shots.
« Last Edit: April 01, 2014, 07:15:44 PM by PrzemoL »
« Reply #48 on: December 01, 2013, 07:31:51 PM »
Hi PrzemoL
You say that you work very slowly, but if the outcome is as good as this then I'm very happy to wait on updates. I had to rub my eyes to believe that this is 1/72.
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #49 on: December 01, 2013, 09:39:28 PM »
 :o
Wonderfull progress Prezmol, I'm speechless!
Best regards,
Sasho
Think globally, act locally!
« Reply #50 on: December 01, 2013, 11:33:33 PM »
Superb work, PrzemoL!  The paint and decals are beautifully done. I really
like the idea for holding the struts in place.  Simple but effective.  Good tip
to remember.  Keep up the good work my friend, you have a winner there.
« Reply #51 on: December 03, 2013, 03:01:06 AM »
Man, she is sure coming together beautifully, Prez!  As always, your painting and shading are brilliant.  You're almost there, buddy.
« Reply #52 on: December 03, 2013, 03:45:22 AM »
Beautiful work as always! You are getting close now !
Online PrzemoL
« Reply #53 on: December 04, 2013, 09:24:48 AM »
Thank you again for your kind supporting words, gentlemen.
Actually it is only tonight that I started to believe I may indeed complete this build. Finally, the top wing and all the struts are mounted, except for 4 inclined ones between the fuselage and lower wing in the inner wing bays and two upper aileron actuators.
I have started with the top wing, then (on the next day) I have trimmed and attached six cabane struts. They had a serious task to do - the top wing was moved by about 1 mm to the side. I have added a block to my jig which moved the wing back to the correct position and then built the cabane. When the CA glue set the geometry was correct. Then the fun begin with trimming, trying, trimming, trying, etc. of the remaining 8 interplane struts. This was going fine until the very last one. I do not know if I was already tired, my hand was shaking, the eyesight getting blurred. I spend a good half an hour trying to check if the strut had correct length. When I succeeded with this part after numerous tries, then it took three attempts to attach it (all the previous ones went on smoothly, each on the first run!). But finally it was there. Then I found, that during the model handling with that last damned strut, one of the float-lower wing lines got loose - one more thing to repair.  >:( But finally I got it all right! I am overjoyed, so please forgive me this longish complaining report.
And now for the rigging!
« Reply #54 on: December 04, 2013, 11:13:05 AM »
Nice work Prez, have fun with the rigging!  ;)
« Reply #55 on: December 04, 2013, 11:26:30 AM »
Beautiful work with the struts and mounting the wing! I am looking forward to seeing her rigged!
« Reply #56 on: December 04, 2013, 11:36:14 AM »
You are doing an excellent job with this model, and now that the top wing is on it looks really good, I'm looking forward to seeing the rigging fitted.
« Reply #57 on: December 04, 2013, 11:58:52 AM »
I seem to have missed this amazing build. Love the scheme!!
Offline Whiteknuckles
« Reply #58 on: December 04, 2013, 02:18:56 PM »
Prez, another gem in the making. :)
You truly are a master with these little beauties and what you do to bring them up to scratch.
Such an interesting livery as well, well done.
Eternal Apprentice
« Reply #59 on: December 04, 2013, 02:31:11 PM »
Looking great Przemyslaw :)
