Author Topic: Mercedes DIIIa  (Read 27424 times)
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Mercedes DIIIa
« on: May 06, 2012, 10:52:28 AM »
These photos are of the restored Mercedes DIIIa engine fitted to The Vintage Aviator Ltd's first Albatros reproduction, ZK-DVA, which is painted as Josef Mai's 5284/17.
If you are modelling the Wingnut Wings Albatros there are some additional details that can be added, if you want to go further than 'out of the box'.
The oil tank has a breather tube (?) and a feed tube:
The air pump as a drain cock coming of at a diagonal angle:
Asbestos cloth wrapped around the inlet manifold:
Note the overhead cam is not black. The kit does not include sparkplugs, which are reasonably prominent:
Here is a link to album (19 photos):
http://s1011.photobucket.com/albums/af234/Jamo_kiwi/Mercedes%20DIIIa%20engine%20restored/
« Last Edit: May 06, 2012, 10:55:21 AM by Jamo »
Happy Modelling
James Fahey
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: Mercedes DIIIa
« Reply #1 on: May 06, 2012, 11:06:45 AM »
Another TVAL Albatros reproduction 7343/17 also has an original Mercedes DIIIa engine but it varies from the one above by having a hot water jacket/double-wall in the intake manifold, which did away with the need for the Asbestos wrapping.
Notice the priming cups fitted alongside the sparkplugs:
Check out the fuel leads to the twin carbs:
I don't fully understand what function some of these items have:
The kit fuel tank caps have no detail. This photo shows what could be added:
Here is a link to the full album with 50 photos:
http://s1011.photobucket.com/albums/af234/Jamo_kiwi/Mercedes%20DIIIa%20engine%20with%20jacketed%20inlet%20manifold/?start=all
Happy Modelling
James Fahey
Offline Tony Haycock
Re: Mercedes DIIIa
« Reply #2 on: May 06, 2012, 04:14:54 PM »
Hi James
The mechanism you aren't sure about looks like the advance/retard mechanism on the magneto to alter the ignition timing.
Tony
Offline Whiteknuckles
Re: Mercedes DIIIa
« Reply #3 on: May 06, 2012, 04:18:18 PM »
Thanks for more great photo's and more resources James.
Eternal Apprentice
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: Mercedes DIIIa
« Reply #4 on: May 06, 2012, 04:56:16 PM »
Hi James
Tony
Sounds good to me, thanks Tony!
Happy Modelling
James Fahey
Re: Mercedes DIIIa
« Reply #5 on: May 06, 2012, 07:36:00 PM »
Excellent photos Jamo, these are a wealth of information for the modeler, thank you for posting them.
Offline Jose Chaica
  • Jose "Von Muttley" Chaica
Re: Mercedes DIIIa
« Reply #6 on: May 06, 2012, 08:34:21 PM »
Excellent photos! Many thanks, James.  :)
Jose Chaica, from Portugal.
Re: Mercedes DIIIa
« Reply #7 on: May 06, 2012, 11:20:44 PM »
All the reference you need. Thanx!!!!
Re: Mercedes DIIIa
« Reply #8 on: May 07, 2012, 12:20:08 PM »
  James,
Thanks my old friend for suppling even more outstanding photo references to us.
Offline kornbeef
Re: Mercedes DIIIa
« Reply #9 on: May 08, 2012, 01:02:51 AM »
AMS FRENZIEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE  :D
wow
Offline Pete Nottingham
Re: Mercedes DIIIa
« Reply #10 on: May 09, 2012, 05:25:30 PM »
Many thanks for sharing the photos James, a great source of information and reference.
Pete.
Offline Bob Sands
Re: Mercedes DIIIa
« Reply #11 on: September 12, 2012, 09:33:02 AM »
  I'm a new guy, so please be gentle,...
  1.  Is there an easy place to go for reference material about these engines?
  2.  With exposed valve springs, were they "evil" messy things?  I'm remembering the time I left the oil filler cap off the car.  Inattention has a way of teaching you things!
  Thanx  Bob
Re: Mercedes DIIIa
« Reply #12 on: September 12, 2012, 10:02:54 AM »
Bob, to answer your second question somewhat obliquely, a few general observations:
-- Valve springs per se do not require lubrication.
-- Poppet valves are typically not lubricated in their guides with engine oil, rather by the inherent lubricity of the fuel (and exhaust) mixture.
-- The cam, cam followers and rockers are most definitely lubricated by engine oil, but in the case of the D.III the messy bits are enclosed by the rocker covers.
In short, my guess is the thing probably throws a bit more oil than a modern engine, but nothing like the total loss system of a contemporary rotary.
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
Re: Mercedes DIIIa
« Reply #13 on: September 12, 2012, 10:55:49 AM »
Hi Bob
Another angle on your question is to look at the photos as a working engine not a museum piece, so what you see is what you get. The TVAL planes are flown reasonably frequently and exhibit a similar kind of usage you expect from WWI. Some of the engines and airframes are quite grungy with exhaust and oil, especially the rotaries and Beardmore.
James
Happy Modelling
James Fahey
Re: Mercedes DIIIa
« Reply #14 on: September 12, 2012, 07:15:45 PM »
Thanks for the superb reference, James.
Out the box has never been so much fun!
Bob  :D
