Author Topic: German oxygen equipment and other fittings  (Read 5913 times)
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« on: August 24, 2013, 09:05:18 PM »
Found these photos browsing the internet:
Manufacturer: Ahrendt & Heylandt
Interesting document in German goes with it:
http://www.cockpitinstrumente.de/instrumente/katalog%201WK/diverses/Atemgereate%20WK%201.pdf
Generator
Little Reschke prop:
Grease pump for water cooling system
Seatbelts
http://www.cockpitinstrumente.de/instrumente/katalog%201WK/diverses/diverses.htm
Make sure you click on the images to enlarge them
James
Happy Modelling
James Fahey
Offline Jacek
Re: German oxygen equipment and other fittings
« Reply #1 on: August 24, 2013, 10:24:50 PM »
Steel water pump, is not brass . Thanks.
Offline martin
    • Martins Scale Models
« Reply #2 on: August 25, 2013, 12:16:25 AM »
Those are great finds for reference, thanks indeed for sharing.
Martin.
Offline mc65
« Reply #3 on: August 25, 2013, 03:48:20 AM »
wow!
great pictures, thanks for sharing!! :D
Offline Zabu
« Reply #4 on: August 25, 2013, 08:11:29 AM »
Very nice!
Thank you for sharing.
« Reply #5 on: August 25, 2013, 12:41:16 PM »
Thank you Jamo!
« Reply #6 on: August 25, 2013, 07:50:15 PM »
Thanks Jamo. The wealth of material out there is breathtaking - if only the coverage was even across all equipment and aircraft.
« Reply #7 on: August 26, 2013, 01:51:00 AM »
Great pictures, James.  Thank you!
« Reply #8 on: August 26, 2013, 03:52:45 AM »
Some really neat references Jamo. As always, thanks for sharing it with us.
« Reply #9 on: August 26, 2013, 07:37:50 AM »
Pure magic Jamo, thank you for posting the images, these will come in very handy in future builds.
Offline David
« Reply #10 on: August 26, 2013, 10:02:45 PM »
Hi James,
Thank you very much for posting the drawing and the photos.  I found a photo this morning which shows this, or similar equipment.  Whilst looking for this photo so that I could post it on this thread I found another copy of it, which explains why I thought that I had seen the photo before.  You or other members might not have seen it though, so I wanted to show the photo.
The photo won't attach.  The file size might be too large.  I will keep trying.
David.
« Last Edit: August 26, 2013, 10:24:58 PM by David »
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #11 on: August 27, 2013, 05:39:00 AM »
Hi David
Do you use an image hosting service like Photobucket or Flickr? That is the easiest way to show the images here. Or you could use the 'Mona Lisa' button on the message options here and paste in the original URL wherever it is.
James
Happy Modelling
James Fahey
Offline David
« Reply #12 on: August 28, 2013, 08:54:56 AM »
Hi James,
Thank you very much for the reply.  No I don't use an image host, but maybe I need to!  How do you post images on an image host site?  Most of the electronic images I have such as the one I tried to attach are from eBay.  One of the problems with eBay, and this is why I check to see what's on there for sale very regularly is that the pages expire regularly due to the large turnover they have.  I did not record the URL, and even if I did the photo I saw a few days ago would be visible for a while and the version of the photo I saved a few months ago would have expired by now.  Given the circumstances the only two options I have for showing members the photo I tried to post is to try to bring the size down by using a program such as MS Paint, or post it and some other images to a web hosting service.
I really appreciate the reply James, and keep the fantastic photos coming!
David.
« Reply #13 on: August 28, 2013, 09:02:58 AM »
Check you email David, I have sent you some hints on photo storage sites, hope it helps.
Offline David
« Reply #14 on: August 28, 2013, 01:06:30 PM »
Hi Des,
Thank you very much for your message.  I did see your e-mail actually, and I am interested to give the image host you mentioned a go!
Now that I am back home and on the computer I will try to reduce the size of the photo using MS Paint, but if I am not able to do this, and perhaps for the longer term I will investigate image hosting.
David.
