Author Topic: Roden Nieuport 28 1/32nd Scale  (Read 53394 times)
Re: Roden Nieuport 28 1/32nd Scale
« Reply #30 on: July 21, 2013, 12:20:25 PM »
Really beautiful job on the cockpit, Rick.  Take as many pictures as you can at this stage, buddy, 'cause it's all about to disappear.  You're making me want to build another.  This really is a sweet kit.
Thanks Bud, and yes it does disappear. I have held things in place and closed the fuselage. Not much is visible,which as you said earlier , is why the Seat is so important!
Great job in that interior.
The wood effect in the structure and fuselage it's very nicely achieved.
About the pictures, they are in fact a little blured. IMO two things can make that: too much zoom, zooming to close of subject and/or not enough light.
Anyway keep those pics coming!
Thanks to you also Zabu! You are correct as to the focus. LOW light and not enough exposure time most likely.
Really good looking cockpit, Rick.  Thanks for posting the
prototype photos.  Helpful stuff! It's such a shame most
of your good work will be out of sight when the fuselage
is buttoned up. :(  Oh well, as a Nieuport  would say...
C'est la vie. ;)
  Keep up the good work, and the updates coming.
Ernie,
Thanks for your continued positive support! It is appreciated!!
« Reply #31 on: July 23, 2013, 02:05:20 AM »
Looking good, await more pics.
ED
« Reply #32 on: July 23, 2013, 02:15:04 AM »
Nice one Rick..
I think anyone's brave to take on a non Wingnuts build!
« Reply #33 on: July 23, 2013, 11:43:52 AM »
ED
Thanks Ed, As I always say, Your comments are always greatly appreciated!!
Nice one Rick..
Guy, Not so brave! The kits take work but are really overall not as bad as most perceive. They aren't WNW but they can be built,as others have shown, to a high standard by a "True" Craftsman!" I fall somewhere in between  ::)
« Reply #34 on: July 24, 2013, 06:33:56 AM »
Good news for today! My Seat arrived from Ron. Very Nice and I will have it painted and detailed with belts in the next 2 days!
« Reply #35 on: July 24, 2013, 12:40:23 PM »
I did a little work on the Engine. Like the interior the detail will disappear once the Cowling is on so I didn't go too crazy  8) I also experimented with some Splatter of oils on the firewall and inside of the cowling.
« Reply #36 on: July 24, 2013, 12:43:09 PM »
and the cowling:
« Reply #37 on: July 24, 2013, 01:06:54 PM »
Excellent job on the engine, Rick.  The oil looks convincing.
Offline Dal Gavan
« Reply #38 on: July 24, 2013, 05:34:22 PM »
Rags wrote: " I fall somewhere in between".
Rags, you're doing a great job, mate.  So stop with the mistaken modesty and show us some more piccies, please.   ;D
Dal, watching intently.
« Reply #39 on: July 24, 2013, 09:36:42 PM »
Thanks Bud! The oil stains won't be seen but what the Heck  :o
Thanks Dal. Not mistaken Modesty. I build nice models but I don't go to the Level of a Des or Justin, or Bud, etc. I am happy where I am ;D
« Reply #40 on: July 24, 2013, 10:48:42 PM »
Nice job on the engine Rick. I have to say that building these rotary engines are my favourites as there's just the right amount of extra detail to add for my tastes.
« Reply #41 on: July 25, 2013, 01:33:01 AM »
Thanks Chris. Your comments are appreciated! As for the details on the engine it should actually have 2 plugs per cylinder. I just couldn't bring myself to cut off the kit supplied plugs, and scratch build 18, on something that won't be seen.  ;D
« Reply #42 on: July 26, 2013, 09:02:30 AM »
Here is my latest update. I received Rons beautiful Resin Seat. I don't know if it is due to my assembly of the interior or another issue but the seat would not fit in my Pre Assembled interior framework. My E Mail was down due to my PC issues and I kind of gave up on Rons seat. I started a 3 hour process of trying to modify the kit seat to the "Peach Basket" style. My far less than satisfactory results are shown in the first 2 pictures. On the Plus side this effort was a learning experience and I could SEE, and more importantly "Feel", Yes I am a Tactile Learner", where I went wrong and felt confident I could scratch build a better example. I then thought of sending Ron a PM. He suggested a method to adapt the width of the seat to make it fit, I went a step further and sanded off the bottom leaving the peach basket sides, then reshaped the cushion to match the Roden seat width. I then re-glued the sides to the cushion and had a very nice, narrower seat. Ron was very supportive and without his initial suggestion of a V cut in the seat I wouldn't have thought to fix my issue as I did! I want to note that the seat as Ron supplies may fit/work if built in from the start, or also if using the Part PE framework which Ron used as a reference. The last pictures are of my modified Ron Kootje Models seat. Sorry but again a bit fuzzy! Finally although the process sounds difficult, the ultimate fix of Rons seat took about 10 minutes of sanding and gluing time!!!!
« Reply #43 on: July 26, 2013, 09:10:28 AM »
Now the Modified seat from Ron:
« Last Edit: July 26, 2013, 09:12:06 AM by RAGIII »
« Reply #44 on: July 26, 2013, 12:33:34 PM »
Good to hear the seat problem was rectified, Rick.
The seat looks perfect.  Onward and upward!
