Author Topic: improvement of Academy Sopwith Camel wicker seat  (Read 2916 times)
Apache Arrow
« on: April 23, 2013, 03:33:04 AM »
  Does anyone have suggestions or a tutorial on how to improve the Academy Sopwith Camel wicker seat?  I really like the look of Des's modification, but can't seem to find instructions on how he did it.
Re: improvement of Academy Sopwith Camel wicker seat
« Reply #1 on: April 23, 2013, 07:30:17 AM »
Brian Fawcett makes a great resin wicker seat to suit your Camel, it is very similar to the one I used on my build, you will find it in the link below.
http://www.fawcettmodelsandpatterns.co.uk/1-32-scale-resin-detail-correction-parts
Apache Arrow
« Reply #2 on: April 24, 2013, 12:55:17 AM »
   Thanks, Des.
« Reply #3 on: April 24, 2013, 01:42:01 AM »
Just curious, the Academy Camel is the Hobbycraft kit but is it the intial release or the improved later version?
Offline kornbeef
« Reply #4 on: April 24, 2013, 03:40:17 AM »
iTS THE EARLIER VERSION.... HO HUM
Didnt mean to shout! :o ;D
« Reply #5 on: April 24, 2013, 07:48:45 AM »
The later improved version is as scarce as hens teeth, but the Academy/Hobbycraft kit does make up to be a pretty good looking model, yes, it needs work but it's all fun.
Academy 1:32 scale Sopwith Camel F.1
« Reply #6 on: April 24, 2013, 08:31:21 AM »
Des you certainly did make a silk purse out of that one!
Offline Fokker boy
« Reply #7 on: December 24, 2014, 01:53:14 AM »
Good to know about the AM seat, as I have recently acquired the Hobbycraft kit (LeRhone), and would really like to replace the kit seat. The Part P.E. seat looks nice, but is probably too "fiddly" for these shaky old hands, caused by too much coffeine.
Kevin
Offline Edo
« Reply #8 on: December 24, 2014, 04:33:24 PM »
well, you could also try to knit one by yourself... it is not that hard but it does require a great deal of patience.... but, again, also everything else in our hobby deoes requre loads of it!  ;)
I tried myself a couple of times and the results were not so bad to my eye....
If you care, you can have a look in my DH2 build which is underway.
Have a nice Christmas and a very bright start in the New Year!
to all of you!
ciao
edo
Offline gcn
« Reply #9 on: December 24, 2014, 05:04:19 PM »
I'm in exactly the same position as I'll be building mine up next. I have worked out 5 options.
Use the kit part
Make one following numerous blogs on the net
Buy the resin version
Buy a sprue from WNW with a seat on. Off the top of my head there's the snipe and bristol
Crush a kit that I've already built for the seat. I do this anyway as my display space is limited.
Initially I think I'll have a go at making one or buying a resin version.
Oh there's the part of Poland set too.
Offline Rob Hart
« Reply #10 on: December 24, 2014, 11:48:18 PM »
Lonestar models makes some wicker seats also:
http://www.lonestarmodels.com/Conversions-1-32.html
