Author Topic: My first WNW build- the Albatros D.V, in the homestretch  (Read 12878 times)
Offline xmald
Re: My first WNW build- the Albatros D.V, in the homestretch
« Reply #45 on: April 12, 2013, 11:02:59 PM »
GREAT GREAT GREAT ;D
Best regards
Filip
Offline bbrockel
« Reply #46 on: April 16, 2013, 01:57:58 PM »
Very nice job.  Great paint scheme.
"If at first you don't succeede, use a bigger hammer"
Offline timpivonka
« Reply #47 on: April 18, 2013, 02:01:35 AM »
Great looking model.  I have Radu's woodgrain masks and am waiting to try them out.  You did
a beautiful job with them.  Encourages me to try them sooner, rather than later.  Also one of
my favorite schemes.  I did the same one years ago on a 1/48th Eduard model.
Thanks for posting, Tim P.
Offline Vickers
« Reply #48 on: April 18, 2013, 09:19:22 AM »
Thanks, mates!  Tim, you may have noted that even though I thinned my paints for the brown and reddish woodgrains they still came out quite dark and distinct. So, I had to tint my varnish a bit more opaque and lay it on thicker than intended.  It still turned out golden yellow, but a bit more intense than I was after. Depending on which of the varnish tones you're after (clear, honey yellow, or red-brown, I'd recommend a test on scrap plastic with the same base coat you intend to use on the model to ensure that you avoid the problem. The masks seem to be fairly resilient and cleaned up very well with just a dip in thinner, so I will certainly use them again on my D-III, but I will definitely test my grain colors before commiting mask to model.
« Reply #49 on: May 04, 2013, 07:03:46 AM »
Duh, just found this, seems to have all happened while I was traveling... lovely build Vickers!!!
« Reply #50 on: May 04, 2013, 09:01:36 AM »
An outstanding project Vickers, you are doing an excellent job with this build, the paintwork and decal application is superb and the rigging looks great, well done for your first WnW build.
