Author Topic: Bad day at the office  (Read 2818 times)
Offline DaddyO
« on: July 05, 2025, 04:27:11 AM »
Bit of disaster getting some models out for the show on Sunday  :'(
Glass shelf collapsed onto the shelf of models below. A few minor damaged models which I'll get round to repairing, but sadly this lot bore the brunt of the impact and are probably for the scrap heap (or at least in need of major rebuilds) Represent about 12 months worth of modelling . . . .
DSC_1710 by Paul S, on Flickr
DSC_1712 by Paul S, on Flickr
DSC_1718 by Paul S, on Flickr
DSC_1715 by Paul S, on Flickr
Offline DaddyO
Re: Bad day at the office
« Reply #1 on: July 05, 2025, 04:29:35 AM »
And the other couple
DSC_1713 by Paul S, on Flickr
DSC_1714 by Paul S, on Flickr
Couple of figures on the Jasta diorama were damaged and the odd wheel on a couple of others which can be repaired with a bit of care, but sadly these are looking the worse for wear
« Reply #2 on: July 05, 2025, 04:36:57 AM »
That is a catastrophe without a doubt - a modellers nightmare. I do hope that you can restore at least a couple of them.
I also have glass shelves but I have made sure that they are stable - and now I know why!!
Offline DaddyO
« Reply #3 on: July 05, 2025, 04:42:53 AM »
Cheers Stephen, These things happen ( I dropped a box of packed figures at a show many years ago causing some damage that was repairable) This little lot sadly will take some effort. As you say a couple should be repairable without the damage being visible, others are likely to be broken up for parts or re-built in other ways (I'm thinking the LVG is going to end up in a minor crash diorama . . . maybe) ???
Offline Richtrad
« Reply #4 on: July 05, 2025, 07:07:19 AM »
Noooooo! That stinks! And it seems neither puppies or kittens were involved. Small consolation might be that even broken they still look pretty amazing.
Warren Q
Offline DaddyO
« Reply #5 on: July 05, 2025, 07:51:54 AM »
Warren Q
  :D thanks Warren.
(Puppies and kittens definitely banned from the workroom, although I am wondering why) Still the sun will keep shining and they've given a lot of pleasure even if they can't be repaired (and I think a couple can without it showing)
Offline enathan
« Reply #6 on: July 05, 2025, 08:42:21 AM »
As you say Paul, these things happen.
The V.23 looks repairable and it's the rarest of them, and a scrach build if I remember correctly...
Offline Dirigible-Al
« Reply #7 on: July 05, 2025, 05:03:41 PM »
Don't scrap them! If they cannot be repaired one of two things could be done. A crash schene diorama or alternatively a post armistice scene whereby aircraft were piled up in a field. I saw an archive picture of this, it was in Italy or the former AHE and the aircraft piled up were war reparations to Italy. There must have been similar pictures elsewhere of both aircraft and equipment if googled.
Alan.
Offline DaddyO
« Reply #8 on: July 05, 2025, 06:37:42 PM »
Cheers matey
Yep the V23 was a scratchbuit. Undercarriage is brass and can be straightened out with wheels being drilled out and brass axle fitted. Wing should bend back into position and hopefully won't need too much touching up. I've started with the Floh which has similar damage; once that's done I'll tackle the V23.  :D
Alan.
Good idea Alan (When say scrap I'm thinking more of complete rebuilds rather than break up for pieces)
I'll start with the two simple repairs and then look at the Albie and Pfalz. Suspect both will need top wing/rigging removed so these may give the opportunity to give them a repaint in different schemes  :-\ (I was rooting through various books this morning to see how much extra work would be involved)
The LVG and DR1 took most of the impact. The Dr1 is the first model I built and all the plastic struts need replacing (I've got some spares) - time for a new scheme on this one methinks  ;) The LVG is a tricky one, but liek you I'm thinking a rebuild into a landing 'crash' will work. I'll sort the others out first and then take a closer look
« Reply #9 on: July 06, 2025, 02:48:43 AM »
How shockingly devastating for you, Paul! What a mess to have to deal with. A terrible event in the life of a modeller (and it's happened to me a few years ago in a smaller way but luckily nothing was un-fixable). Good luck with your repairs!
Offline DaddyO
« Reply #10 on: July 06, 2025, 03:09:51 AM »
Cheers Gary
An opportunity for some different schemes on the Albie and Pfalz maybe . . .  :-\
« Reply #11 on: July 08, 2025, 09:31:32 PM »
OMG!! I go away for a few days and this happens! You clearly cannot be left without adult supervision......
Seriously, what a disaster. I'm gutted for you. I hope it doesn't dent your mojo too much......
Offline DaddyO
« Reply #12 on: July 08, 2025, 09:54:44 PM »
Sadly not safe to be left alone for 5 minutes ;D
Sh*t happens, as they say, matey. I'll get the easy ones repaired first and then back onto the Tripe because I'd really like that one off my workbench (None of the allied aircraft were damaged so should be okay for the upcoming show)
Per aspera ad astra
ps - First job was actually fixing teh shelf supports which has now been sorted pretty thoroughly  ;)
« Reply #13 on: July 08, 2025, 10:08:52 PM »
Oh my, I am so sorry... Try to save as many as it can be. Good luck!
Offline DaddyO
« Reply #14 on: July 08, 2025, 10:38:26 PM »
Thanks Prze
I'm pretty sure they'll all reappear in some form or another, but some are a little more involved so may need top wings removing, complete re-rig etc. I'll add pics to the repaired versions to this thread as they are (re)done
