Author Topic: Pfalz D.III exterior question  (Read 983 times)
Offline Chuckt5
« on: May 17, 2025, 10:23:27 AM »
Just wondering if the Pfalz exterior would show nail heads like the Albatross or was the same unique to the Albi?
Re: Pfalz D.III exterior question
« Reply #1 on: May 17, 2025, 03:18:24 PM »
Hi Chuck ,
To answer your question ...No there no nails like on the Albbies .
Once the two halves of the fuselage were joined , it was wrapped in linen ,  the seems got taped over and sealed . Painted to seal and water proof it .
Offline Umlaufmotor
« Reply #2 on: May 17, 2025, 10:48:31 PM »
Hi Chuck,
Alexis is absolutely correct.
The Pfalz D.III/D.IIIa, D.VIII, D.XII had clean hulls without nails and screws.
Only a few screws, for example the screws on the hinges of the maintenance hatches and on the outer metal fittings where the seat belts are attached on the inside.
However, you should not forget that the longitudinal seams on the fuselage - i.e. where the sealing tape was glued over it - are visible.
Here is a nice picture of it, directly behind the edge of the cockpit you can faintly make out the glued-on fabric sealing tape:
Servus
Bertl
Offline Chuckt5
« Reply #3 on: May 18, 2025, 12:40:44 AM »
Thank you gentleman for the valuable information. It?s very much appreciated.
C
« Reply #4 on: May 20, 2025, 01:11:37 AM »
Your welcome Chuck , but not sure I'm a gentlemen , don't have the right parts for that !
Offline Chuckt5
« Reply #5 on: May 20, 2025, 01:58:04 AM »
I beg your pardon! Sorry about that.
« Reply #6 on: May 20, 2025, 02:25:07 PM »
Will admit Chuck , you had me worried , just had to run to the ladies room to double check , all is still good !
Are you working on a Pfalz aircraft ?
Offline Chuckt5
« Reply #7 on: May 21, 2025, 12:50:34 AM »
I gathering my research info in the hopes to get rolling on the build.
Sorry again about the screw up. I was reading the responses on my phone (without my glasses) and I clearly missed out on some crucial info!
« Last Edit: May 22, 2025, 01:17:40 PM by Chuckt5 »
