Author Topic: Albatros D.V, R. Flaschar (1/72, Eduard)  (Read 9388 times)
Re: Albatros D.V, R. Flaschar (1/72, Eduard)
« Reply #15 on: May 03, 2025, 07:26:24 PM »
Thank you, Brad. Your absolutely correct remark triggered the decision to rebuild the interior. I decided to split it into twoand disassemble to be able to correct also the not inline longerons... Keep your fingers crossed. ;)
« Reply #16 on: May 05, 2025, 03:01:31 AM »
The truss split into two. Reassembled, some more scraping in the front and finally it fits, with the engine and with the upper longerons aligned with fuselage rim.
Online NigelR
« Reply #17 on: May 05, 2025, 07:25:44 PM »
Now that is dedication to accuracy! Super work.
« Reply #18 on: May 06, 2025, 01:59:45 AM »
PE = The devils details
Looking good so far ...
Offline Brad Cancian
    • Brad's Models
« Reply #19 on: May 06, 2025, 06:30:45 PM »
Love-el-ey!
« Reply #20 on: May 07, 2025, 02:30:33 AM »
Thank you for your approval. 😉
And in the meantime lots of fun with PE and scratch details for the cockpit and Mercedes engine.
« Reply #21 on: May 07, 2025, 04:07:43 AM »
Some great, dedicated work there. Looking sharp!
Online NigelR
« Reply #22 on: May 07, 2025, 06:06:57 PM »
That is all simply amazing for 1/72!
« Reply #23 on: May 08, 2025, 05:36:10 AM »
Thanks, Warren and Nigel.
Today just two bits, but built from scratch - fuel and oil tanks.
« Reply #24 on: May 08, 2025, 07:00:05 AM »
Man alive!
How you boys work in 72nd is beyond my comprehension.
I'm glad you do, cos I get to watch and marvel.
Nicely done, Prze!
Bob  ;)
« Reply #25 on: May 08, 2025, 09:55:52 AM »
Prze!
        How did you create the spouts, filler caps for the fuel tank?
« Reply #26 on: May 08, 2025, 04:18:30 PM »
Prze!
Short sections of plastic round profile or soldering wire glued into drilled holes. Caps from spare PE discs.
« Reply #27 on: May 09, 2025, 05:40:36 PM »
The seat. Kit part has thick walls, Part PE is surprisingly too narrow. So I decided to thin the walls of the kit part from the outside.
And some more bits added to the engine - flywheel and water pump with the pipe.
« Last Edit: May 09, 2025, 05:45:02 PM by PrzemoL »
Online NigelR
« Reply #28 on: May 09, 2025, 06:04:13 PM »
More impressive attention to detail, well done.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #29 on: May 09, 2025, 06:33:28 PM »
Very nice additions! Looks great  :)
//Ben - @AngryJazz_Models
