Author Topic: Albatros D.V, R. Flaschar (1/72, Eduard)  (Read 9350 times)
« on: April 26, 2025, 04:01:06 AM »
Time for the new project.
Albatros D.V from Jasta 5, 1/72, Eduard kit, Part PE especially for the interior truss, Roden Mercedes engine and probably some scratch.
Scraping of interior of fuselage halves has just begun.
Online NigelR
Re: Albatros D.V, R. Flaschar (1/72, Eduard)
« Reply #1 on: April 28, 2025, 07:22:47 PM »
A nice project, I'm looking forwards to see what you do with all that photoetch in this tiny scale..... :)
« Reply #2 on: April 30, 2025, 04:28:15 AM »
Slow progress.
Assembly of PE interior truss is tricky. And Eduard plastic is quite hard and not east to remove. But for now - going forward.
Online NigelR
« Reply #3 on: April 30, 2025, 05:54:19 AM »
That looks pretty daunting....... Don't breathe too hard on that photoetch!
Offline Kamil Zoszak
« Reply #4 on: April 30, 2025, 06:11:30 AM »
Hi Przemek
I didn't realized that,  those PART PE set will fit to Eduards model.
« Reply #5 on: May 01, 2025, 12:48:11 AM »
Great start to this build Prze. I?ve never had any luck getting the Part PE interior framing to fit into the Roden kits. But I never sanded away the molded details. Looking forward to seeing how all this works out for you.
All the best,
Tim
« Reply #6 on: May 01, 2025, 08:21:26 AM »
The Part interior truss can be squeezed into the fuselage only after the sides are substantially thinned, does not matter if it is Roden or Eduard or any other kit. I have done it several times on various kits including Albatros D.II and D.III. But it is my debut with D.V.
So scraping the interior and assembling the truss continues. Scraping will keep my busy for some more time certainly...
Online DaddyO
« Reply #7 on: May 01, 2025, 03:27:33 PM »
Lovely to see that brass-work Prze (shame most of it'll disappear later) ::)
I seem to spend a lot of time sanding and thinning parts and as you mention the Eduard plastic, whilst lovely and sharp, can be hard work. Doesn't look like you've got too far to go now though :D
« Reply #8 on: May 02, 2025, 02:33:55 AM »
The engine cowling will be off, cockpit opening is quite large, lots of the interior truss will be seen.
And there is still some thickness to go  ;)
Online NigelR
« Reply #9 on: May 02, 2025, 04:48:12 AM »
Well done for getting that etch to fit without squashing it!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #10 on: May 02, 2025, 05:49:00 AM »
Impressive work in that scale! The PE would scare me, but you make it look great  ;D
//Ben - @AngryJazz_Models
« Reply #11 on: May 02, 2025, 11:53:25 AM »
I don't envy you all that work, Prze, but you're doing a great job. Bravo!
« Reply #12 on: May 03, 2025, 12:45:19 AM »
Thank you.
It looks like the thinning reached the goal. The truss sits well inside. And Mercedes, too.
Offline Brad Cancian
    • Brad's Models
« Reply #13 on: May 03, 2025, 10:58:28 AM »
Very impressive as always Prze!
One question; should the upper stringer in the nose be level with (or just below the line of) the plywood panel? It could just be the way that it's dry fitted that makes it stick up a bit proud.
Otherwise, looking forward to yet another master class!
BC
« Reply #14 on: May 03, 2025, 01:18:50 PM »
Very impressive work, Prze. Your level of patience for a job like that  is very admirable.
