Author Topic: "Shelf Queen 2025 GB" Eduard 1/48 Hannover CL.IIIa....FINI...  (Read 10389 times)
Offline Allan31
Re: "Shelf Queen 2025 GB" Eduard 1/48 Hannover CL.IIIa....
« Reply #15 on: March 03, 2025, 08:26:41 AM »
Thanks Nigel,
Lozenge...
I used close colors as the factory would have.
I made a template and cut friskit masks.
I will give myself a break and apply lozenge decals for the upper colors then clean the airbrush and tackle the lozenge on the fuselage.
This is a very tedious painting process, I can see why an all red triplane is appealing...
« Last Edit: April 20, 2025, 10:50:49 PM by Allan31 »
Offline Flamingo
« Reply #16 on: March 03, 2025, 08:42:31 AM »
That is looking very promising!
Hawas are rather challenging projects.
Regards Joachim
jets are for kids
« Reply #17 on: March 03, 2025, 05:14:51 PM »
Nice progress on the Hannover. Your wings look great!
« Reply #18 on: March 03, 2025, 07:47:50 PM »
Lovely work, well worth the effort. But it is a LOT of work. Probably why I will do the plain training machine when I build my WNW kit....
« Reply #19 on: March 04, 2025, 12:34:01 AM »
Outstanding results on the center section Lozenge!
« Reply #20 on: March 04, 2025, 01:07:58 AM »
Great job on the upper wing lozenges Alan. I remember painting mine a few years ago and ended up doing it twice  :(
« Reply #21 on: March 04, 2025, 04:39:27 AM »
It is a serious modeling project. I will follow with a great intrrest.
Offline Allan31
« Reply #22 on: March 09, 2025, 06:41:50 AM »
Thanks all, this a tedious build.....
Before I can start painting on the lozenge fuselage, I had to finish any surgery and PE work.
It took me awhile to figure out what was going on with the lifting hand holds.
Eduard has them as just plates.
I then added the rest of the extensive PE they provide.
Eduard would have me apply a circular hatch as on the port side but I needed louvers. Shaped stretched sprue.
Using furnace tape, I created some missing details on the wings and fuselage.
I'm adding a Gas Patch Spandau so I excavated a place for that. I will make ammo chutes.
Sadly, those rocker arms and push-rods are taking a beating. I will have to come up with something.
Now I can finally get to finishing the lozenge decals and airbrushing.
And just when I thought my Hannover building could not get any worse, I found this in the stash while looking for something else....
(heavy sigh.....)
« Last Edit: March 09, 2025, 07:57:43 AM by Allan31 »
« Reply #23 on: March 09, 2025, 09:29:25 AM »
Your mods to the Eduard kit continue to be first rate improvements! That old Airfix kit will be even more challenging, or so I imagine. Too bad those decals look like they are shot. Those spiffy markings would have been cool  8)
« Reply #24 on: March 09, 2025, 07:49:11 PM »
Great job on the fuselage!
« Reply #25 on: March 09, 2025, 07:53:42 PM »
Excellent work, your use of stretched sprue for the louvres is superb.
« Reply #26 on: March 09, 2025, 11:15:32 PM »
Superb work Allan. I?ve never worked up the nerve to individually spray lozenge cammo. You did a terrific job. The Gaspatch Spandau looks great there in its excavated space.  Looking forward to the fuselage!
All the best,
Tim
« Reply #27 on: March 10, 2025, 01:41:49 PM »
Nice work so far Nigel on the details . Haven't built this kit many many moons ago now it was a challenge for me back then . It is when I got into building WW 1 Aircraft . I bought this kit and the SSW D.III . Still have another Hannover in the stash so will be making a few building notes as I follow along .
Offline Allan31
« Reply #28 on: March 13, 2025, 07:45:18 AM »
I was not happy with the way these Vallejo paints brush out so airbrush it is.
I used the 1/48 scale drawings in the Datafile #23 and traced off the side views on tracing paper.
In pencil I roughed in where I thought I wanted the shapes then did an ink tracing of that and made 2-3 copies.
I started with the yellow over all.
Using Friskit material, made for airbrushing, I cut out the numbered colors I needed. If your copy gets too cut up, use another copy. Do not cut on your original.
I'm not going to bother touching up as this will all be covered with a translucent coat of Prussian Blue.
More soon.
« Last Edit: March 14, 2025, 06:34:36 AM by Allan31 »
« Reply #29 on: March 13, 2025, 10:23:44 AM »
It looks awesome to Me! You make this Lozenge masking look easy...although I know it isn't!
