Author Topic: WnW Albatros B.II old build - new propeller  (Read 1958 times)
« on: October 22, 2024, 11:04:35 AM »
A couple of years ago I built the WnW Albatros B.II and was happy with it. While walking past it as it sat in my display case, I couldn't help notice that the way I'd painted the laminated wood on the propeller, and how poorly done it was. There's nothing worse than odd looking propeller wood laminations (or poorly aligned turnbuckles) on a WW1 aircraft.
So after literally years of looking at this I finally said to myself "That's it!" and dug out the alternate propeller for that model, and painted it up to look the part. I did a bit of research on Reschke propellers, and gave it my best effort to fix my mistake and get the laminated wood to look like it should. I had to make a new rear hub from styrene, but I'm much happier with the overall look of the model now.
Once a model is finished, I've always thought that it should be left alone and the next effort would be better. But this one begged to be fixed with a propeller replacement.
New propeller painted up for the Albatros B.II model
The Reschke propeller was an option for the particular scheme of my aircraft.
My original pant job on the Garuda type - which looked poorly done in my humble opinion. Not sure why it took me years to finally fix it.
Re: WnW Albatros B.II old build - new propeller
« Reply #1 on: October 22, 2024, 06:58:35 PM »
A lovely BII Gary. That original propellor doesn't look too bad to me, certainly better than some of my earlier efforts. But the new one looks spot on, so well worth that extra bit of effort.
« Reply #2 on: October 22, 2024, 08:49:12 PM »
An improved propeller is always welcome :)
Great job, Gary.
Online DaddyO
« Reply #3 on: October 22, 2024, 10:11:49 PM »
Nice job on the new prop; it now compliments the model (which is lovely) beautifully.
ps - Can't understand why the old two seat Albie isn't more popular with modellers - it makes a beautiful model with the challenge of interesting surfaces to paint/recreate
Online lcarroll
« Reply #4 on: October 22, 2024, 11:07:24 PM »
   Very nice upgrade on an already beautiful model Gary. Your re-work was well worth the effort!
« Reply #5 on: October 22, 2024, 11:28:43 PM »
Thanks Nigel, Prze, Paul, and Lance
Paul - you ask a good question, but I have to admit that the Albatros B.II model is the "wobbliest" of all the WnW kits I've built when it comes to sitting on it's landing gear. The legs are so spindly and have to support a fair bit of weight...and in my case the left side has even bowed a bit over time which has the model sitting at a very slightly odd angle (which is hard to fix). I'll have to ignore that...but did fix my coolant vent pipe which had apparently separated from the upper wing (after seeing it in my posted photo!).
« Reply #6 on: October 26, 2024, 08:37:57 AM »
Thatis a superb model Gary. Improving the prop will hopefully allow you to admire it as much as the rest of us - because I would have been proud enough with the older prop!
Offline P.P.
« Reply #7 on: October 28, 2024, 02:20:42 AM »
It is perfect work and i do like the ancient look of this aircraft.
« Reply #8 on: October 28, 2024, 08:47:00 AM »
Sheer perfectionism in action!
« Reply #9 on: October 30, 2024, 02:42:00 AM »
Excellent Retrofit !!
« Reply #10 on: October 30, 2024, 07:00:44 AM »
Excellent work, Gary.
Thanks for sharing.
Offline ModelCellar
« Reply #11 on: November 06, 2024, 11:48:54 PM »
Looks great Gary.
« Reply #12 on: December 17, 2024, 11:23:22 AM »
I agree with My Amigo!
