Author Topic: Pfalz D.VIII, Harold Auffarth, Jasta 29 (1/32, Aviattic) - completed  (Read 28787 times)
Offline FokkerFodder
Re: Pfalz D.VIII, Harold Auffarth, Jasta 29 (1/32, Aviattic)
« Reply #105 on: August 18, 2024, 02:49:19 PM »
I love the colours on this and it’s looking great… a real brute of a plane!
Matt
« Reply #106 on: August 18, 2024, 04:32:48 PM »
Stunning build!
Offline DaddyO
« Reply #107 on: August 18, 2024, 05:07:24 PM »
Really enjoying this build Prze and love the detail you're adding along the way  8)
« Reply #108 on: August 18, 2024, 10:56:37 PM »
Beautiful paintwork and tastefully weathered! I Love this one.
Offline Umlaufmotor
« Reply #109 on: August 19, 2024, 01:14:39 AM »
Propulsion unit mounted!
Funny enough, I have not glued the engine, only the prop is attached to it and the whole set can rotate, as if it was ordinary rotary. I know it is not correct for the bi-rotary SSh engine. But it will allow me to present the model with various prop orientations. And I can still pour CA glue to make it fixed, if I am bored with it ;)
@Przemol
@Davos522
Hello PrzemoL, Hello Dutch,
don't let your thoughts lead you astray!
Seen from the outside, the Siemens Halske ShIII is exactly the same as a normal rotary engine.
The propeller is bolted to the engine housing and therefore - logically - rotates at the same speed and in the same direction as the cylinders rotate.
The special feature of this engine compared to a normal rotary engine is that the crankshaft INSIDE the engine rotates at the same speed against the direction of rotation of the cylinders.
The SHIII rotates at a maximum of 900 rpm in one direction and the crankshaft at 900 rpm in the other direction - this results in an effective speed of 1800 rpm.
If the propeller on the model rotates in the same direction and at the same speed as the engine, this is absolutely correct!
And by the way PrzemoL - an excellently built model is currently being built on your workbench  ;)
https://www.enginehistory.org/Piston/Before1925/SiemensHalskeSh3/01Sh3.gif
https://www.enginehistory.org/Piston/Before1925/SiemensHalskeSh3/03Sh3.gif
https://www.enginehistory.org/Piston/Before1925/SiemensHalskeSh3/05Sh3.gif
Servus
Bertl
« Last Edit: August 20, 2024, 09:28:45 PM by Umlaufmotor »
« Reply #110 on: August 19, 2024, 01:35:39 AM »
It is hard to digest that I lived so long with the wrong idea of birotary engine principle...  :-[ But then, thank you Bertl for straightening it out! And my pleasure is now doubled as it turned out that my ad hoc mod of the engine assembly is correct  :D
« Reply #111 on: August 19, 2024, 06:49:53 PM »
This is looking beautiful Przem, you are really doing this kit justice. Is the prop painted or carved? If painted, how the heck did you manage it?
« Reply #112 on: August 19, 2024, 06:56:56 PM »
Thank you, Nigel!
But...
we have had the discussion about cheating with the propeller :)
https://forum.ww1aircraftmodels.com/index.php?topic=14419.msg264965#msg264965
Mine is carved from pre-cut veneers - which you considered as cheating, indeed ;-)
https://forum.ww1aircraftmodels.com/index.php?topic=14419.msg266501#msg266501
Offline AngryJazz
    • @AngryJazz_Models
« Reply #113 on: August 19, 2024, 06:59:40 PM »
Stunning, just stunning! The color, the prop just amazing!  ;D
//Ben - @AngryJazz_Models
« Reply #114 on: August 19, 2024, 09:20:37 PM »
Ah, I'd forgotten that. You did indeed cheat ;) ;D but you made a fantastic job of the propellor, it does look really good. And the four-bladed Wotan is virtually impossible to paint anyway.
« Reply #115 on: August 20, 2024, 12:35:34 AM »
The rigging stations in, some did not stand the pull off test - reinserted and awaiting the second test.
« Reply #116 on: August 20, 2024, 05:59:07 AM »
And now the assembly is started. Cabane struts on place, with the use of a cardboard jig. And the test of dryfit of the upper wing. BTW, the wings are so thin in profile and made from a soft resin that they hog down under self weight. I wonder if the addition of struts will be enough to help or will the rigging need to be really working as in the real thing  :)
« Reply #117 on: August 20, 2024, 07:40:55 AM »
And out of the sudden... it is a biplane  :)
« Reply #118 on: August 20, 2024, 09:32:06 AM »
Simply Gorgeous!!!! You make Me wish this one was in My poor Mans price range  ::) Probably best as it would be Impossible to build as fine a Model as you are presenting!
« Reply #119 on: August 20, 2024, 03:05:46 PM »
Very satisfying updates! And what a pretty plane it's turning out to be!
