Author Topic: 1/72 Roden Pfalz DIII  (Read 33169 times)
Online DaddyO
Re: 1/72 Roden Pfalz DIII
« Reply #45 on: July 25, 2024, 05:05:44 PM »
Never quite sure what glue to use for the tiny brass detail bits;
Another possibility is a drop of clear paint.  I've tried it for 1/700 doors and hatches and the results are no worse than any other product.
Rick in Seattle
Cheers Rick. :)
 A drop of paint would do it (I tend to use varnish for the same results) Given they were being fitted at an early stage and my tendency to 'over-handle' (if that's a thing) a model during construction I opted for the messier choice. Paint or varnish is my preferred adhesive for adding small finishing details; maybe I'll give it a shot next time and see how I get on; as you say it's unlikely to be worse than any other adhesive given the surface area.
ps - bought a couple of 1/700th kits full of enthusiasm until I saw the tiny, tiny detail bits. I tip my cap to you sir  8)
Offline Allan31
« Reply #46 on: July 25, 2024, 08:52:27 PM »
Loverly progress.
I have used clear Future as an adhesive for tiny bits with good success.
« Reply #47 on: July 27, 2024, 05:22:18 AM »
Looking Awesome!
Offline Skyhook
« Reply #48 on: July 28, 2024, 01:39:11 AM »
Great work! And thumbs up especially for tackling a 1/72 Roden subject. They are great, if you do some pre-fitting and planning before taking the glue out. Looking forward to your progress with the Pfalz…
Cheers, Skyhook
Online DaddyO
« Reply #49 on: July 28, 2024, 01:54:16 AM »
Loverly progress.
Thanks Allan  8)
Looking Awesome!
Cheers RAGIII  ;D
Cheers, Skyhook
Thanks Skyhook  ;D
Yep they are a bit more involving that the usual throw it in air with a tube of adhesive type of kit, but I prefer that to be honest. Not keen on the Roden Albatros 3 piece wings though; I've tried 3 now without being happy with any so the W4 I've started has now got Pegasus wings ready to be added  ;)
Adding some paint to the Pfalz as we speak.
I decided to paint the fuselage black after priming and then mask the stripe before adding the silver. I thought that might be easier than trying to do it the other way and hopefully it will give a slightly different 'look' to the fabric and solid areas which is apparent in photos.
I also decided to paint the tail and spinner white first and then mask the spots before adding the red
All sounds like a plan, but I'm at  a show tomorrow so hopefully some updates on Monday
Online DaddyO
« Reply #50 on: July 29, 2024, 05:14:20 PM »
As promised here are the bits so far with some paint added ready for the masking and famous Pfalz silver to be applied  ;D
Offline AngryJazz
    • @AngryJazz_Models
« Reply #51 on: July 29, 2024, 05:40:07 PM »
Close to some color! Cant wait!
Very nice work  ;D
//Ben - @AngryJazz_Models
« Reply #52 on: July 29, 2024, 06:07:26 PM »
That looks like a lovely precise build so far. It's a pity that black fuselage is going to disappear under mostly silbergrau...... ;) Best of luck with the masking.
Online DaddyO
« Reply #53 on: July 30, 2024, 03:02:13 AM »
Cheers Ben and Nigel  ;D
Decided I was feeling a bit under the weather so took the day off work. Luckily I wasn't so ill that I couldn't raise myself from the bed to do a bit of masking and spraying  ;)
Here in it's unedited glory is the result. A few bits of touching up needed, but can't really complain. The silbergrau is a tad silvery for my taste, but better that way because I can teak it at the weathering stage.
« Reply #54 on: July 30, 2024, 03:16:42 AM »
Looking good, Paul, and that's a great scheme. Can't wait to see this one done!
« Reply #55 on: July 30, 2024, 05:03:28 AM »
Awesome paint work Paul! You have done fantastic work on the ribbon and dots! One of My favorite Pfalz Schemes although I have yet to model it on one!
« Reply #56 on: July 30, 2024, 06:07:19 PM »
Great job on the masking for a guy at death's door...... ;) I couldn't do that in 1/32, let alone 1/72!! Fab stuff indeed.
Online DaddyO
« Reply #57 on: July 30, 2024, 06:23:38 PM »
Cheers Dutch. I just noticed that the fuselage crosses have a 'silver' outline where they intrude on the spiral but I think I have a plan to sort that  . . . . :-\
Thanks RAGIII . There's a bit of glue residue from the frisk film I used for the dots, but I'll get that cleaned off and then do a spot of touching up (see what I did there?) ;)
Thanks matey  ;D
Feeling a bit better today and the boss is complaining so I'd best be doing something workwise today and get back to this later . . . . ::)
« Reply #58 on: July 30, 2024, 06:37:02 PM »
Very fine colours! Watching with great interest.
Offline Dirigible-Al
« Reply #59 on: July 31, 2024, 12:06:48 AM »
I knew this would look good and by Jove it's certainly going that way.
Cheers, Alan.
