Author Topic: 1/72 Roden Pfalz DIII  (Read 33300 times)
Re: 1/72 Roden Pfalz DIII
« Reply #75 on: August 09, 2024, 09:54:16 PM »
The cross outline looks Perfect! The wing is looking good and great that it will soon be a biplane! You are definitely tempting Me to look for another 1/32nd Roden kit to try that Jasta 4 ribbon again!
Offline DaddyO
« Reply #76 on: August 12, 2024, 02:57:57 AM »
Aha, I like the subtle approach ;) I think I can just about see some weathering in the fuz photo but it's more visible on the wing and looks very nice. Will need to do a close up inspection in person.....
;D Quality that photo mate, sheer quality LOL. Really must look into something more suitable for taking these piccies, but they give you the idea at least  ;)
Really nice Paul. I appreciate the subtle weathering and very much like your decal touch up.  Looking forward to the upper wing attachment.
Tim
Cheers Tim, got there in the end. ;D
Go on RAGIII you know you want to . . .
Just knocked up a suitable jig from foam board, but needed to spend the morning sorting out an issue with the car and it's been too hot in the workroom to do anything this afternoon so I'll be up at crack of dawn tomorrow to hopefully turn the bits into a biplane
« Reply #77 on: August 12, 2024, 03:21:36 AM »
Inspiring scheme! Well done on the outline.
Offline DaddyO
« Reply #78 on: August 15, 2024, 05:07:40 AM »
Cheers Fredrik
For those interested here's how I usually make a jig using photocopies of plans and foam board.
Offline DaddyO
« Reply #79 on: August 15, 2024, 05:10:46 AM »
And thanks to some early starts I now have a biplane (albeit a slightly hairy one) ;)
Rigging is my usually drilled through the surfaces, 1lb fishing line and superglue. I'll leave that to dry this evening and then trim off the ends before making good and adding the decals
(Dirty fingernails courtesy of a bit of work on the car) ;D
« Reply #80 on: August 15, 2024, 05:19:31 AM »
The rigging is looking great Paul! You are nearing the finish line!
« Reply #81 on: August 15, 2024, 06:28:06 PM »
That jig looks like a lot of work for a tiny plane....! :) But the result is worth it, she is looking very nice.
I assumed that was why you had taken to wearing nail varnish...... ;D
Offline DaddyO
« Reply #82 on: August 15, 2024, 06:35:42 PM »
Getting there RAGIII, but even by my own sloth like rate of building this one is dragging on . . . ;)
LOL, I've got some lovely matching red for the final pics Nigel  ;D
« Last Edit: August 17, 2024, 08:56:03 PM by DaddyO »
Offline DaddyO
« Reply #83 on: August 17, 2024, 09:08:37 PM »
Okay plenty done this week, but not much that's obvious  ::)
Lines all trimmed, filled and sanded off. (I did notice I'd rigged one incorrectly so that needed to be replaced)
Tips of guns added and then I realised I hadn't drilled the holes for the various piping arrangements in the fuselage before doing the rigging so a bit of dexterity needed to overcome that. The pipes were from 0.2 and 0.3 mm brass that had been annealed to make it easier to bend. A few spark plugs added to the engine which had broken off or been damaged during construction masking and although they'll be pretty difficult to see when the exhaust goes on I thought I'd better replace them. Small pressure header (?) added to top of radiator from carved sprue and wire.
I really enjoy these little bits and can now see the finish line with this one . . . . ;D
Hopefully cool enough for final decals this weekend and then I suppose I'd better add some wheels  ;)
« Reply #84 on: August 18, 2024, 06:06:11 AM »
Beauty in the making.
Offline Brad Cancian
    • Brad's Models
« Reply #85 on: August 18, 2024, 09:01:33 AM »
Looks great! That touch up around the cross and the rigging looks very well done. Hat's off, sir!
BC
« Reply #86 on: August 18, 2024, 04:37:28 PM »
A great build to follow! Impressed by the detailing in this scale.
Offline DaddyO
« Reply #87 on: August 18, 2024, 04:49:37 PM »
 ;D Many thanks Prze
BC
Cheers Brad (Touch up looks okay at a distance) ;)
Glad you're enjoying it Fredrik.  ;D
Slight pause in proceedings now because I managed to slice open the back of my thumb yesterday.  ::)
They avoid stitching in that area nowadays so I've been superglued back together and so I'm be a bit restricted holding things using my left (non dominant) hand for a few days.
Still I can decide on the next project . . . currently a choice between finishing a RNAS Nieuport 17bis conversion or starting a Martinsyde Elephant/Harry Tate or Dh4 (all 1/72)  :-\
Offline Flamingo
« Reply #88 on: August 18, 2024, 05:01:52 PM »
Excellent!
jets are for kids
« Reply #89 on: August 18, 2024, 10:59:21 PM »
Glad you were able to add the piping and replace the springs without too much trouble! Rigging is looking amazing!
PS: I missed the Finger Part originally. Hope you Mend quickly!
« Last Edit: August 19, 2024, 02:39:52 AM by RAGIII »
