Author Topic: Replicating Fokker Plywood Wings  (Read 5086 times)
« on: April 23, 2024, 11:42:36 AM »
Since my WnW E.I is temporarily on hold due to issues with the decal end of the project, I thought I'd use the down-time to jump to the other end of the Eindecker spectrum and start the Mikro Mir 1:32 E.V/D.VIII kit, which I recently got from UA-Hobby in Kyiv. I've always wanted to build this type, primarily because a) I've loved them for about sixty years (I was never able to find the Aurora kit when I was a kid, more's the pity), and b) I was fascinated by the challenge of capturing the uneven surface of the ply-covered wing. I've been mulling over ways to replicate that wavy effect in plastic for decades:
I spent a week or two researching Fokker construction techniques (Achim Engel's two books on his D.VIII reproductions were invaluable resources), and started by glueing the wing halves together and filling the oversized (and incorrectly placed) panel lines with stretched sprue laid down with liquid cement, then sanding them flush:
Starting on the underside, I brushed on a quick primer coat of Floquil/Poly Scale "Mud" (no particular reason, it just happened to be handy), and after figuring out the actual panel lines using photos from the Engels books as reference, used a plan of the sub-structure from Datafile 25 as a guide to draw the spars and ribs on with pencil, and the panel joints with a .005 Pigma Micron:
That done, I re-scribed the panels, then began trying various methods of making shallow depressions in the surface. First I tried using a rotary tool with a pointed felt tip and jeweler's rouge, then a blunt toothpick dipped in abrasive compound, then a shaped coffee-stirer with padded sandpaper super-glued to it... but none of them really worked. Finally I began lightly scraping "dips" where the plywood was unsupported using the rounded edge of a No. 15 scalpel blade (the areas on the left in the photo below):
That worked, but despite my lightest touch it still left tiny but visible gouges in the styrene. So I ended up wet-sanding all 164 divots with 320- and then 400-grit sanding film (beginning with the center section above the wing cutout in the photo above).
It took hours, but I'm fairly happy with the results; the mirror-smooth surface of the plastic has been broken up into a subtle but highly realistic pattern of high- and low-spots that mimic the underlying ribs and spars:
[/url]
The effect isn't quite as pronounced as that oblique lighting makes it appear, but it gets the effect across...
I'm planning on finishing the model as one of the aircraft flown by either Stefan Stec or Stefan Bastyr during the Polish-Ukrainian war in 1918-19. Since this is most likely going to be another long-term undertaking I probably won't do a full-blown build log, but I had a lot of fun with this part and thought it might be worth sharing.
Now that I have the technique figured out all I have to do is repeat the whole process on the upper side of the wing...
All best,
« Last Edit: April 23, 2024, 12:40:20 PM by Davos522 »
Offline Edo
Re: Replicating Fokker Plywood Wings
« Reply #1 on: April 23, 2024, 03:28:57 PM »
wow!
you effort surely payed off!
ciao
edo
« Reply #2 on: April 23, 2024, 04:02:01 PM »
Great efforts. And the results is very convincing - it should not be too overdone, just visible with the light passing almost parallel to the surface - exactly what you achieved!
« Reply #3 on: April 23, 2024, 06:15:21 PM »
Now that is superb modelling, and great attention to detail. Very impressed......
« Reply #4 on: April 23, 2024, 11:13:17 PM »
   ........ and I'll double Nigel's endorsement Dutch, great effect and tempts me to make a second effort at this kit. VERY impressive work indeed!
« Reply #5 on: April 24, 2024, 02:31:24 AM »
Yup, that looks really spot-on, Dutch. What an improvement to the kit. If it's a Polish crate I assume it'll be green wings?
You mention the old Aurora kit, I was so pleased to get one as a kid and carefully painted the wing lozenges by hand to reproduce the box art. DOH! Only later to repaint it all green when I discovered it was a plywood wing. Of course that was probably no more accurate as we know now!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #6 on: April 24, 2024, 03:43:33 AM »
Now this is extraordinary! Well done! It looks amazing  ;D
//Ben - @AngryJazz_Models
« Reply #7 on: April 24, 2024, 12:31:42 PM »
Thank you, everybody, like I said it was a lot of fun experimenting and trying different techniques. Sandy, I'm not sure about the colors of the wing, as I'm still waiting for a couple of references to arrive; the one I'm really looking forward to reading is one PrzemoL recommended to me, Polish Wings No. 25. But if I have it correctly (via War Wings Over Galicia 1918-1919) the fighters used in Poland were all E.Vs except for a sole D.VIII, and the Arma Hobby instructions for their little 1:72 kit show the wings as being green/brown and magenta/blue stain. So that's what I'm leaning towards at the moment.
All best,
« Reply #8 on: April 24, 2024, 01:33:09 PM »
Bravo Dutch, that's fantastic!! I don't envy the trial and error, nor the amount of work required, but the results show your time was well spent. Wow!
« Reply #9 on: April 24, 2024, 08:51:59 PM »
All best,
While you are waiting for the book, I can confirm - here the current state of the knowledge has that all Polish Flying Razors had the four-coloured wing.
« Reply #10 on: April 25, 2024, 06:17:51 AM »
I thought that I was a glutton for punishment.... but I think that you win the award for finding the most time consuming and tedious process in WW1 modelling!
The effect looks superb - I hope that it is further enhanced when you paint it.
Thanks for showing us - any technique is useful and who knows, one day I might be doing something similar.
Offline Brad Cancian
    • Brad's Models
« Reply #11 on: April 25, 2024, 07:21:32 PM »
Amazing modelling Dutch! I am blown away by the attention to detail here :)
Looking forward to seeing more of this project.
BC
« Reply #12 on: April 26, 2024, 01:47:20 AM »
That is a very clever idea!
« Reply #13 on: April 26, 2024, 04:39:09 AM »
Wonderful work Dutch!
« Reply #14 on: April 26, 2024, 03:03:30 PM »
Agree! Well done!
/F
