Author Topic: Replicating Fokker Plywood Wings  (Read 5066 times)
Re: Replicating Fokker Plywood Wings
« Reply #15 on: April 27, 2024, 12:24:07 AM »
Outstanding results Dutch! I have another kit but I don't think I am ready for that challenge. When I do build another one I will get the Brass aftermarket struts and save Myself some stress  8)
« Reply #16 on: April 28, 2024, 12:55:42 AM »
Just catching up and that definitely hits the mark!
« Reply #17 on: May 07, 2024, 12:03:22 PM »
Again, thanks for the comments... while the E.I is still in a holding pattern I'm whiling away my time on her younger sister the E.V. Since I'm going to experiment with not only replicating the uneven effect of the Fokker ply-covered wings, but the wood-stain camouflage finish as well, I wanted to begin with a natural plywood base:
It'll only be partially visible under the faded brown/green/blue/violet, so I didn't waste a lot of time on the graining, then it got a couple of coats of Dullcote lacquer since I wanted a bulletproof foundation to experiment on... wish me luck on this one.
And although it's not part of the wing, the fuselage interior does incorporate plywood, so I thought I'd throw in a gratuitous shot of that too:
I had a couple of sheets lying around so I used some Aviattic ply and interior lozenge, the stringers are .030x.010 Evergreen styrene strip that I threw a quick graining effect on.
All best,
(Moderators: If this goes any farther I'll start a separate build log, I promise!)
« Reply #18 on: May 07, 2024, 06:06:17 PM »
Interesting to see this one progress. I discovered that Aviattic had some EV streaking decals which IMO look quite good, I have some in my stash for my EV build. I'll be keen to see how you approach this.
« Reply #19 on: May 08, 2024, 05:13:07 AM »
Looking very good Dutch! If you proceed to streaking, camo that is, Please add that portion to the Fokker Streaking thread in Hints and Tips!
