Author Topic: 1/72 Short S 38 on HMS Africa and HMS Hibernia 1912  (Read 19931 times)
Re: 1/72 Short S 38 on HMS Africa and HMS Hibernia 1912
« Reply #15 on: January 25, 2024, 06:53:58 AM »
Excellent progress Stephen, she’s shaping up very nicely!
« Reply #16 on: January 25, 2024, 09:20:09 PM »
Wonderful work thus far, Steve -
Going to look fantastic on your ship turret display when complete.
« Reply #17 on: February 08, 2024, 09:21:56 AM »
Evening All,
Thanks Nigel, Joachim, Zac and Dave for dropping by and leaving encouraging comments - they are very much appreciated.
I have made some progress with this project, but did have a case of two steps forward and one back, which meant that I had to dissemble and re-assemble some parts. I completed the addition of the interplane and boom struts after the initial assembly had dried out: this was a straightforward task as it involved gently placing the ends of the struts into the pre-drilled holes in the wings after I had place a small drop of glue into the relevant holes. The boom struts were cut to exact length and fixed in place with CA:
When I added the supporting struts for the upper wing overhang I did not cut them to the correct length and as a consequence I distorted the wing and boom structures. It took me a whole evening of fiddling and thinking before I realised the cause of the problem, by which time I had partially dissembled the top wing. Fortunately as soon as I removed the outermost interplane struts the problem was resolved: the wing was re-assembled and new outer struts cut and glued into place and all was square again.
I made the front booms from brass bar as the originals were square section. I measured the gap between the wings using a pair of dividers and marked the where the ends of the booms needed to be with a pencil on a piece of paper. I could then lay the brass bar on the paper to form two V's which I was able to solder:
After the joints had been cleaned with a file I was able to CA the repective booms to each side of the front of the model. I started rigging the model at this stage because some areas will be difficult to reach later. The wings and boom bracing was rigged using rolled copper wire held with CA:
I have now reached a snag: the undercarriage was a simple structure consisting of two struts on each side supporting two skids. The axle ran across the skids. This will be an inherently weak part of the model which will require careful handling, especially when rigging. In addition if I finish the aircraft before I make the turret and foredeck on which I intend to mount it, I will have to be very careful in storing the aircraft model to stop it being accidentally damaged, so I have put it to one side for the moment while I concentrate on the base.
I have made a small start on the base but am still in the process of studying photos of the deck and turret to work out some of the smaller details. I am not a ship modeller so I am on a very steep (vertical?) learning curve at the moment, but in the last couple of days I have had access to some very helpful information with the help of a fellow modeller and I hope to be able to present the results of my research in model form before too long.
Thanks for looking.
Offline torbiorn
« Reply #18 on: February 08, 2024, 08:33:37 PM »
Great project - planes on ships are my favourite type of planes. Of course, that runway covers the entire forecastle, not just the turret. Can we goad you into building the whole thing? ;D
« Reply #19 on: February 08, 2024, 08:53:24 PM »
What a pain and trial for you, Steve over the wing and struts.
Still, at least you have sorted it now and it is showing great promise.
« Reply #20 on: February 09, 2024, 04:34:19 AM »
Thank you Tjorborn and Dave for the kind comments.
Tjorborn: if I were to construct the whole of the foredeck of the ship the aeroplane would be a tiny feature at one end! It would also take me a very long time because of the anchor chains and associated equipment, not to mention the other paraphernalia on the sharp end of a battleship!
Offline Flamingo
« Reply #21 on: February 09, 2024, 07:27:35 AM »
Nice progress! Will watch with great interest.
Joachim
jets are for kids
« Reply #22 on: February 09, 2024, 08:19:48 AM »
Top notch work Stephen - I can't believe how thin that rigging is!!
« Reply #23 on: February 15, 2024, 09:40:47 AM »
Evening All
Thanks Joachim and Zac for your kind comments - they are very much appreciated. The wire looks so thin Zac because it is copper wire which is actually incredibly thin and IMHO does look realistic despite the colour.
Many thanks for your (too) kind comments - they are greatly appreciated. I have given a lot of thought to the undercarriage problem but cannot drill holes under the wing because in the front there is a strut in the way, and at the rear the boom is where the undercarriage leg is to be attached. I will probably have to use butt joints which are not the strongest attachment, but I am hoping that if the model is secured to the launch platform it will have sufficient strength to hold properly.
I have become a ship modeller recently: usually I make aeroplanes so I am learning fast. When I dropped into my LMS and asked for a kit of the front turret and foredeck of an Edwaed VII class battleship of 1912 in 1/72 scale I just received a blank stare! I started by downloading a plan and side elevation of the foredeck of HMS Africa/Hibernia and enlarged it until 1mm represents 1 foot. I could then draw a plan at 1/72 scale where 1 inch represents 6 feet.
I have made a base which is 12 inches (30 cm) x 11 inches (28cm) from hardboard and painted the edges which will not be covered by the deck white. I used white rather than sea blue because this will not be a waterline model: only the top of the ship sides above the portholes of the crew accommodation will be represented. Three supports from 1 inch x 1 inch (2.5cm x 2.5 cm) wood were glued to the top of the hardboard - these will hold the deck. I shaped 2 pieces of 1 inch square wood to represent the sides of the ship immediately below the deck line and covered the outer faces with 10 thou plastic sheet. These will be painted battleship grey later. The small fillets at the rear of the sides represent the curve of the ship sides above a 9.2 inch gun mounted low down in the hull:
The gaps at the front and rear of the model between deck and base will be covered with plastic card later. The deck was cut form 1/8th inch (2mm) basswood (lime) sheet: 2 pieces were cut and shaped to represent the deck forward of the bridge to a point approximately 30 feet (8.2m) forward of the forward barbette breakwater. The edges were rounded with glass paper and sealed with a mixture of talcum powder and dope:
The circle and arc represent where the barbette and breakwater will be positioned later. The curved rear covered the 9.2 inch guns in the hull and will have 60th plastic sheet CA'd underneath to represent the armoured deck.The top of the deck will be covered with 1/8 inch (2mm) square pine strip to represent the wood planking on the real ships. The barbette was cut form 4 pieces of 1/4 inch (0.5mm) basswood sheet: 2 pieces were joined to form a square sheet and the two sheets glued so that the joints were at 90 degrees. When the glue had set I cut off the waste wood around the circle that I had drawn on one surface, and the final rounding was achieved with a wood file:
I made a block for the turret from 2 inch (5cm) square basswood: I cut a length of wood into two and glued the two pieces together and then added two more pieces of 1/4 inch sheet to the rear of the sides to allow for the wider rear of the turret. The top of the block was removed with a saw:
The front of the turret has also been trimmed to save filing the front face later. I filed/shaped the top of the turret first. I traced the upper and lower surfaces of the turret plan and the faces of the turret sides from the drawing and transferred these to the wood block and cut the sides of the block so that they were almost in alignment with the lower outline:
Starting at the rear I could now file the individual faces of one side of the turret using the lines as a guide:
The above operation was repeated for the other half of the turret and the front surface was also completed:
The rear of the turret had the recesses cut with a saw. I drilled two holes in the front of the turret to take the gun barrels. The barrels of the guns were made from pine dowel which had been turned in an electric drill and sanded to shape with coarse, and polished with fine, glasspaper. The ends were shaped to fit into the holes in the turret.
The turret, gun barrels and barbette were sealed with my go to wood sealant - talcum powder and dope mixture - and sanded smooth:
The gun barrels, turret and barbette have only been placed together for photos and checking fit and position. They will be permanently glued together later.
Thanks for looking.
« Reply #24 on: February 15, 2024, 10:28:40 AM »
This one is truly fun to follow, Stephen, any part of a battleship in 1:72 is automatically going to be awesome, let alone with an aeroplane sitting on top of it.
And your comment about the clerk in your LMS reminded me of the gun-store scene in the original Terminator where Arnold asks for a “phased plasma rifle in the 40-watt range” and the guy tells him “Hey, buddy, just what you see!”
« Reply #25 on: February 15, 2024, 12:37:02 PM »
Dutch: that's a great call!
Wonderful work Stephen and I appreciate you taking the time to show us each step of the process. It demystifies a level of modelmaking that to many - like myself - seems out of reach.
Regarding the copper wire: I was going to ask if you could paint it, but I get the feeling the colour ultimately won't matter when one sees the whole diorama!
Online NigelR
« Reply #26 on: February 15, 2024, 06:53:18 PM »
Wow. Just wow. Amazing work, especially on the base. This will be such a unique model when it's done that it will be worth the effort.
When I dropped into my LMS and asked for a kit of the front turret and foredeck of an Edward VII class battleship of 1912 in 1/72 scale I just received a blank stare!
Now that made me laugh!
Online DaddyO
« Reply #27 on: February 15, 2024, 07:57:23 PM »
Ah the smell of sanding talcum powder and dope - Now that really does take me back  ;D
Lovely work so far and great to see soldered brass being used for struts
Offline Flamingo
« Reply #28 on: February 15, 2024, 08:38:56 PM »
Hi Stephen,
great progress with your gun turret!
Too late for this project but here is my suggestion for the undercarriage problem.
I solder the booms in "side view" and lengthen the interplane struts down to the skid, with a bent angle if necessary.
For the S 38 one could even include the blue strut. Strange that it is attached forward of the boom strut.
The top wing of the S 38 has a convenient cut-out for the rear booms, for my Farman project a three piece wing is needed, Inpact style.
I used this method for my 48th Boxkite but lenghtened one boom at the upper side and wondered why the rear ends were in different heights!!
Maybe this will be usefull for a future project.
Best whishes Joachim
jets are for kids
« Reply #29 on: February 15, 2024, 10:46:44 PM »
Incredible work. Kind of looks like a plunge mold for vaccuform at this stage.
Tim
