Author Topic: WiP - Eduard 1/48 Albatros D.III  (Read 14618 times)
Offline Brad Cancian
    • Brad's Models
Re: WiP - Eduard 1/48 Albatros D.III
« Reply #30 on: September 22, 2023, 06:44:33 PM »
Many thanks gentlemen!
I have now completed the priming. For some reason, the priming stage excites me more than it probably should (and more than many other stages of construction). I am not sure why that is; perhaps it's the revelation of the true 'blank canvas' nature of the model, of the 'artistic' possibilities to come, and the state of readiness for the next (and most important and daunting) part of adventure. Perhaps it's the representation of progress. Perhaps it's the 'unity' that a coat of primer gives to the look of things. Or perhaps I have just had a little too much of the good Gin and Tonic on a Friday afternoon, eh wot.... I don't know... in any case, I'm excited to be at this point!
There's still some quite minor clean up to do, but overall it's coming together well enough.
Cheers!
BC
« Reply #31 on: September 22, 2023, 10:06:39 PM »
I totally agree with you about the priming stage Brad. My thought is that it’s the revelation that all the previous effort has been authenticated and the project is ready to proceed to the color stage.  Your Albatros is looking wonderful.
« Reply #32 on: September 23, 2023, 04:58:52 AM »
Looking really good.
Personally, the priming stage annoys the hell put of me because it reveals that those seams I thought I had filled and smoothed down beautifully are in fact gaping holes that need to be refilled, resanded and primered again....... >:( ;D
« Reply #33 on: September 23, 2023, 09:26:29 AM »
Beautiful. And I'm with you, I really look forward to getting out the primer too.
Also a fan of G&Ts, although in the past few summers the G&F (gin and French, basically a gin and tonic with the addition of vermouth—hugely popular in the Great War) has been my after-work elixir of choice.
    • Brad's Models
« Reply #34 on: September 23, 2023, 08:14:46 PM »
Thanks gents!
Don't worry Nigel, this happens to me all the time also; that's why I started priming back in the day, as I kept finding those little issues after the paint went on, which bugged me. Thankfully this time around, only a couple of minor blemishes to fix up from the priming, which is nice.
Hi Dutch - now I am definitely going to have to try that one - what is your gin of choice, my friend?
Some good progress again today; pre-shading has been done (always laborious when one has to put all of those rib tapes down for masking), and the underside light blue has gone on the lower surfaces of the wings. All going well, tomorrow i'll start adding the colours to the top surface of the lower wing (I'll need to do my own mixes for these... yay).
Cheers again!
BC
« Reply #35 on: September 24, 2023, 10:48:49 AM »
Please post pics of the pre-shading, if you can, that's a technique I've never actually used, despite having read about it many times.
And (off-topic alert!) my "blue ruin" of choice is good ol' Bombay Sapphire, I mix it 50/50 with Dolin or Noilly Prat white vermouth for a gin and French. I originally read about them in the journals of C.S. Lewis's older brother Warren, who spent 1914-1932 as an officer in the Royal Army Service Corps... they were one of the things that helped keep the wheels of Empire turning.
Offline davec
« Reply #36 on: September 24, 2023, 09:30:59 PM »
Looks great!  I agree with your comments about getting to the primer stage.  I just hit the same point myself with my Ninak.  For me it is a transition point where there is less work to do than already done, the end product is visualizable, and where I realize that most of the things that bothered me while I was building won't be visible to anyone but me when it is done.
« Reply #37 on: September 28, 2023, 11:12:19 AM »
Beautiful work Brad, I love the extra work you've put in to making it accurate. The choice of colour scheme is one I too am unfamiliar with and keen to see.
Okay, I have to try this!!
« Reply #38 on: September 28, 2023, 10:14:17 PM »
Your primed Alby looks great - it actually reminds me of the CAD images of up coming new releases.
    • Brad's Models
« Reply #39 on: October 02, 2023, 11:51:18 AM »
Thanks all!
Hi Dutch - here's the pre-shading that i've done; for the upper sides of the flying surfaces and tail I used black mixed with a little dark earth / brown, and for the undersides of the flying surfaces, I used the dark earth / brown by itself. I left the fuselage un-shaded as this will be painted with a wood effect.
One can then use light oversprays of the top colours, such that the pre-shading shows through. This adds some depth to the finish (as seen here on my previous Albatros DV build), i.e:
I now have the underside light blue painted, and the wing camouflage (only the top surfaces of the lower wing, as the upper wing will be the mid green colour, like the tail). I've also now made a start on the plywood fuselage, using some of these trusty old favourites....
I'll post some pictures once the effect is complete. I'll probably have a forced break on this one over the next couple of weeks due to work sending me overseas. On the plus side, that will give those oils plenty of time to dry, but it's going to be a tight run to the finish line...!
Cheers!
BC
« Last Edit: October 02, 2023, 11:57:53 AM by Brad Cancian »
    • Brad's Models
« Reply #40 on: October 02, 2023, 01:42:06 PM »
Also, I have just given said tipple a spin; I must say, the combination of French vermouth and English gin is a fine thing.
Pip pip, eh wot!
BC
« Last Edit: October 02, 2023, 04:57:55 PM by Brad Cancian »
« Reply #41 on: October 02, 2023, 11:01:43 PM »
Cheers, Brad! :D One of my great joys in the summer is usually sitting in our backyard with a G&F, unfortunately because of the weather this past year—hot and rainy—I haven't been able to do it once because of the mosquitoes, which have been out in Wing strength. But that picture is inspiring, now that our summer up here in New England is on the wane maybe I'll try venturing out!
And thanks for the pre-shading tips, I have to give it a try. My No. 2 Son just gave me a double-action Badger Anthem to replace my old single-action Paasche H, and it looks like that would be the perfect tool for experimenting with the technique.
All best,
« Reply #42 on: October 06, 2023, 07:11:34 AM »
Pip pip, eh wot!
BC
Next week I may have to splurge and sample it for myself!
« Reply #43 on: October 09, 2023, 10:24:56 AM »
I was too curious and had to give it a go....then I had another go....delicious
« Reply #44 on: October 09, 2023, 01:18:36 PM »
Seems we now have an Official Cocktail of the WW1 Aircraft Models Forum :-D
As I mentioned I read about them in Maj. Warren "Warnie" Lewis's diary, he said that the gin & French was the usual pre-dinner cocktail in his mess. I've often wondered whether they originally started mixing in the local stuff during the Great War as a method of extending their gin-supply...
