Author Topic: WiP - Eduard 1/48 Albatros D.III  (Read 14617 times)
Re: WiP - Eduard 1/48 Albatros D.III
« Reply #60 on: October 31, 2023, 09:25:14 PM »
Beautiful build Brad. What a stunner.  Such realistic effects with the simulated wood and the added details.  Bravo!
« Reply #61 on: October 31, 2023, 09:27:21 PM »
Excellent work as usual, Brad. I look forward to seeing more information on your woodgrain technique in this scale.
« Reply #62 on: October 31, 2023, 09:38:18 PM »
As beautiful as they come!
Online BobW
« Reply #63 on: November 01, 2023, 12:29:35 PM »
Great work!!!  I really admire your level of excellence.
Buy the way, for the cooling vents, access panels and flaps, etc., did you use aftermarket products?  If so, what did you use?   Earlier in your build you indicated that you removed the styrene cast items on the fuselage.
Bob W.
Offline Brad Cancian
    • Brad's Models
« Reply #64 on: November 01, 2023, 05:38:51 PM »
Thankyou all!
Hi Bob! Indeed, as this one was a weekend edition kit, I used the hatches that come with the Eduard set 48263, which I picked up on ebay a little while back. Similar vents and hatches can be found on sets for the DVa as well.
Cheers!
BC
« Reply #65 on: November 03, 2023, 01:59:41 AM »
Hope you're close - looks like you are - 5 days to go!!
