Author Topic: CSM Bristol Scout C: and Roden Sopwith 1 and 1/2 Strutter 43 sq. RFC  (Read 46589 times)
Re: CSM Bristol Scout C: and Roden Sopwith 1 and 1/2 Strutter 43 sq. RFC
« Reply #30 on: July 09, 2023, 09:53:15 AM »
The end of todays session: Interior work is progressing on the Bristol Scout and some basic CDL has been sprayed in the Scout and Strutter interior.
« Last Edit: July 09, 2023, 11:54:40 AM by RAGIII »
« Reply #31 on: July 10, 2023, 08:22:27 AM »
My Rick: if this is slow progress what would you be like if you built a model quickly?
Super finish on the wood and canvass interiors.
« Reply #32 on: July 10, 2023, 10:51:21 AM »
Thanks Stephen. I did a bit more work today. Wood painted in the Strutter interior and washes added to both models. Drybrushing a lighter CDL shade followed. Still more to do.
and... just for fun I tested the decals. The one I tested came off of the backing paper easily, did not break p or tear, and conformed to a compound surface including raised rivets. I didn't use setting solution but I am certain that would have worked even better. Too bad the color is so dark!
« Last Edit: July 10, 2023, 10:56:51 AM by RAGIII »
« Reply #33 on: July 10, 2023, 12:06:09 PM »
Moving along nicely (and so quick too!)
« Reply #34 on: July 10, 2023, 09:11:24 PM »
Thanks for dropping by Amigo!
« Reply #35 on: July 10, 2023, 09:40:19 PM »
Nice work on the interiors of both, Rick.
« Reply #36 on: July 11, 2023, 05:58:03 AM »
Great work on the interiors so far Rick. The CDL looks lovely and oil stained in the most realistic way.
« Reply #37 on: July 12, 2023, 05:19:30 AM »
Thanks Ken. Not quite as detailed as yours but I think it will be good when I finish the Smoke and Mirrors Methods I use  8)
Thanks Richie. I did a bit more yesterday but not enough to make another post worthwhile!
« Reply #38 on: July 12, 2023, 05:57:46 AM »
I agree with Richie - the interiors look superb.
« Reply #39 on: July 12, 2023, 06:32:05 AM »
Thanks Stephen!
« Reply #40 on: July 12, 2023, 06:57:49 AM »
It will be a treat watching this lovely pair being built. Fine start on both, Rick.
« Reply #41 on: July 12, 2023, 09:29:41 AM »
I agree with Prze, I'm enjoying following along with these two.
« Reply #42 on: July 12, 2023, 05:14:47 PM »
I've not bought a new model for some time now, but both of these are very tempting and it'll be great to follow your builds.
Thanks Fredrik! I will be in touch about these markings I pulled from the Net:
PS: Probably the top one with #4 as it has a bit of the metal panels left unpainted.
No problem Rick!
Just send me a message and I'll crack on. Roundels too? That would sort the dark colour...
Great work so far!
« Reply #43 on: July 13, 2023, 05:12:57 AM »
Thanks Przemo!
Thanks for the comment Zac!
No problem Rick!
Great work so far!
Thanks Fredrik! I have a couple of things to sort out then I will send that PM.
Yesterdays Progress:
Still LOTS to do on both!
« Reply #44 on: July 13, 2023, 05:18:47 AM »
Very nice interior work! I like the Oil stains on the lower part of the fuselage. You can already see that it’s a rotary engine here  :)
