Author Topic: Lohner Tl - L75 (1/32, Lukgraph)  (Read 33051 times)
Re: Lohner Tl - L75 (1/32, Lukgraph)
« Reply #30 on: March 06, 2023, 06:29:55 PM »
I am stunned to see so many progress in so little time Prezmo.
Very neat work on the tail with the reinforcements.
« Reply #31 on: March 07, 2023, 12:16:58 AM »
That’s really impressive how fast you are building this one. And how great it looks!
« Reply #32 on: March 08, 2023, 04:33:13 AM »
Thanks, gentlemen.
Some more work, though not so quick as over the weekend.
Replacements for flattish PE control horns made from scratch.
And the dry fit of lower wings. For a moment the holes in the wings for the steel wire are drilled tightly (1.2mm) and not accurately. I will redrill them later with a larger dia drillbit (1.3mm) to have a margin of movement to fit them to the planned cardboard rig in order to control the dihedral and sweepback angles. The photo is just a teaser  ;)
« Reply #33 on: March 09, 2023, 09:07:58 AM »
Today it was all about struts. Now all are fitted with wire inserts and all but last three polished to remove the printing traces.
« Reply #34 on: March 11, 2023, 09:37:40 PM »
More preparations.
Trolley and trestles bits cut from the trees awaiting cleaning. Upper wings bits cleaned and armed in wire sections for better strength. And yes, this beast will be HUGE.
« Reply #35 on: March 11, 2023, 10:02:26 PM »
It's good to see how thoroughly you prepare every part before building. I need to follow this example!
The fuselage looks really beautiful.
« Reply #36 on: March 12, 2023, 06:08:48 PM »
I am really curious how you‘ll stack up all those hundreds of struts on to the lower wing!
« Reply #37 on: March 12, 2023, 08:49:50 PM »
It will be a challenge. But the plan is to build the centre tower with the engine first. Then put the upper wing on, and add the outer interplane struts. When it sets well - add the inner interplane ones and rigging. The supports of cantilevers  at the end. Wish me luck  ;)
« Reply #38 on: March 17, 2023, 07:23:26 PM »
Some more fitting, including the cardboard rig. Also all the holes for rigging stations have been drilled. Time to start the paintjob.
Offline jeroen_R90S
« Reply #39 on: March 17, 2023, 09:05:25 PM »
That looks gorgeous -Lukgraph seem to improve with each release, too :)
« Reply #40 on: March 20, 2023, 08:58:42 AM »
Lower wings got their pattern of spars and ribs on the underside and then got finally glued to the hull using the rig.
Rigging stations under preparation. Today the eyelet counter reached 82.
« Reply #41 on: March 20, 2023, 11:51:58 AM »
This is looking so nice!  I’m curious to see how you will paint the wooden hull under the wing bracing.
« Reply #42 on: March 20, 2023, 10:29:33 PM »
Przemo, my wife is very angry at you. You make me spend money on my first airplane model without wheels.
Until now I actually passed all float planes or flying boats, but that one and like you build it start to change my mind …
« Reply #43 on: March 21, 2023, 07:57:56 PM »
Great work there, Prez -
Really taking shape now
« Reply #44 on: March 21, 2023, 08:23:32 PM »
Thank you, gentlemen.
Does it mean that your wife supports your building the land planes only?  ;)
Well, try to convince her that the flying boats are beautiful - especially those from Adria war theatre which had so fancy colour schemes, both Italian and A-H ones.
She may change her mind  ;D
