Author Topic: WNW Roland DVIa  (Read 23951 times)
Offline stefanbuss
Re: WNW Roland DVIa
« Reply #75 on: March 21, 2013, 05:13:40 AM »
Maybe you might want to apply a wash to the engine bay, too? I think this will diminish your feeling about a bad wash for the cockpit, as there will be less discrepancy?
The enine still looks ok. I would not change that, again.
Just go ahead!
Stefan
Offline Pete Nottingham
Re: WNW Roland DVIa
« Reply #76 on: March 21, 2013, 05:32:45 AM »
Hi Stefan;
Yes I will be applying a wash to the engine bay as well, hopefully it will be a bit more 'oily'.
Pete.
Re: WNW Roland DVIa
« Reply #77 on: March 27, 2013, 08:50:27 PM »
Well the latest update will be some time coming, I'm gonna have to revert to the standby engine, the new engine has gone hopelessly wrong, I've never known more things go wrong on a build, ever, I just don't have any luck on Rolands at all.
Pete.
Re: WNW Roland DVIa
« Reply #78 on: April 06, 2013, 12:01:18 AM »
Well, I've buttoned up the fusilage ok, it's painted and oiled, I'm using the reserve engine, hopefully pics will follow shortly.
Pete.
Re: WNW Roland DVIa
« Reply #79 on: April 06, 2013, 12:11:01 AM »
  Pete,
Keep up the excellent works my old friend.Looking forward to the latest photos.
Re: WNW Roland DVIa
« Reply #80 on: April 08, 2013, 08:18:26 PM »
Morning all;
At last an update of the build, ready to start adding the pretty bits now.
Pete.
Offline Vickers
Re: WNW Roland DVIa
« Reply #81 on: April 08, 2013, 09:22:51 PM »
Your clear varnish over unstained wood looks spot on, Pete.  The contrast between the fuselage and the lightly golden-stained vertical tail surfaces adds a very nice touch. Lovely build you've got going here!
Re: WNW Roland DVIa
« Reply #82 on: April 08, 2013, 09:48:40 PM »
Thanks Vickers.
Pete.
Offline Andi Little
Re: WNW Roland DVIa
« Reply #83 on: April 08, 2013, 10:46:09 PM »
I just keep seeing something new everyday - I'm loving the varnish over timber effect - subtle, and beautiful.
KBO ............. Andi.
Offline michael
Re: WNW Roland DVIa
« Reply #84 on: April 08, 2013, 10:52:11 PM »
That wood looks very very nice Pete!
how did you do it, if you dont mind sharing your secrets  ;)
michael
Re: WNW Roland DVIa
« Reply #85 on: April 09, 2013, 12:17:53 AM »
I'll add kudos as well Pete. If you have no luck with Rolands it's certainly not apparent here, the wood planking finish is exceptional! It's looking like a a very nice finished product to add to your display.
Re: WNW Roland DVIa
« Reply #86 on: April 09, 2013, 01:35:58 AM »
   Pete,
Wow that's some of the best light colored wood work I'm seen by anyone. I absolutely love what you've done. OUTSTANDING!
Re: WNW Roland DVIa
« Reply #87 on: April 09, 2013, 02:28:56 AM »
Thanks for the comments guys, I really appreciate them.
michael
Hi Michael;
For the wood effect, I used Vallejo Model Air Sand (71075) for the base coat, then for the fusilage I used Winsor & Newton Griffon Alkyd fast drying oil colours, these are the ones that dry overnight, very useful, I mixed White and Burnt Umber to get the light effect and thin coated the fusilage, I added some more Burnt Umber to darken the mix a bit and put a few streaks on and brushed them in, I then let this dry overnight, then put some random dots of the mix on and using a very large dirt encrusted finger rubbed them in.
For the vertical tail, same base colour, then for the paint mix I used White and Raw Sienna using the same technique as the fusilage except for the large finger part.
Pete.
« Last Edit: April 09, 2013, 05:07:49 PM by Pete Nottingham »
Re: WNW Roland DVIa
« Reply #88 on: April 09, 2013, 02:44:43 AM »
Excellent work!!
Offline michael
Re: WNW Roland DVIa
« Reply #89 on: April 09, 2013, 03:36:07 AM »
Cheers Pete it looks stunning
michael
