Author Topic: 1:32nd scale Fokker E.IV  (Read 11607 times)
Online Dirigible-Al
Re: 1:32nd scale Fokker E.IV
« Reply #15 on: January 06, 2023, 12:39:04 AM »
I like your work on the interior Mike.
Alan
« Reply #16 on: January 06, 2023, 04:03:12 AM »
Very neat as ever Mike.
Somewhat off topic but I have been having a good look through your BE2c pdf. Thanks so much for making it available, the rigging plan is going to be so useful to me.
« Reply #17 on: January 06, 2023, 10:56:36 PM »
Great progress. The completed cockpit displays perfect painting of the various materials.
« Reply #18 on: January 08, 2023, 10:26:43 AM »
Your interior could be confused with photos of a full sized replica! Awesome Mike!
« Reply #19 on: January 10, 2023, 08:29:58 AM »
I've replaced the kit supplied machine guns.
Instead I've used the 'Gaspatch' MG 08 equivalent weapons.
This meant a few modifications to both kit supplied and 'Gaspatch' parts.
« Reply #20 on: January 12, 2023, 03:49:18 AM »
The Fokker company burnished or turned the exposed metal surfaces of the 'Eindeckers'.
'Wingnut Wings' suggest representing this effect by brushing with thinned 'Tamiya' Aluminium and Chrome paints.
I think for many modelers this can be problematic, trying to brush paint thin and consistent 'squiggles' over the parts.
Instead I tried an easier and much quicker method, as follows:
Airbrushed with 'Tamiya' Gloss Black (X1).
Airbrushed with 'Alclad' Duraluminium (ALC102).
Airbrushed with 'Alclad' Flat clear coat (ALC314).
'Squiggles' drawn using a standard 2B pencil.
Airbrushed with 'Alclad' Light Sheen clear coat (ALC311).
The final clear coat highlights the graphite in the pencil squiggles.
Of course I then realized that most of this will have to be lightly over-sprayed with the green dope for this particular model - hey-ho.
« Reply #21 on: January 12, 2023, 04:13:15 AM »
Impressive squiggle work Mike! Too bad it gets "Mostly" covered.
« Reply #22 on: January 12, 2023, 11:05:24 AM »
Hi Richie,
Glad it came in useful,
« Reply #23 on: January 12, 2023, 12:21:05 PM »
Impressive squiggly technique.  Looking very nice!
« Reply #24 on: January 12, 2023, 07:50:12 PM »
Great job on the cockpit, engine and those metal panels. It will be a pleasure to watch.
« Reply #25 on: January 13, 2023, 06:06:21 PM »
Interesting technique! Saved for later use.
Thanks for showing and explaining.
« Reply #26 on: January 14, 2023, 02:18:03 AM »
Your squiggle method is perfect. That's a keeper tip!
« Reply #27 on: January 14, 2023, 07:31:24 AM »
The cockpit and top coaming panels now fitted.
As usual, most of the cockpit detail is not visible.
The green paint or dope over the Fokker effect metal panels was oil paint.
'Mig' 3506 Field Green (Oil Brusher) applied then removed using a soft, broad brush with 'Mig' Odourless thinners.
The applied Fokker effect can still be seen through the paint.
More weathering has to be applied so this is just the base covering.
« Last Edit: January 14, 2023, 07:40:30 AM by Mike Norris »
« Reply #28 on: January 14, 2023, 09:00:40 AM »
Engine and cowl assemblies fitted.
Fuselage side fairings and underside deflector fitted.
Now onto the fuselage weathering,
« Reply #29 on: January 14, 2023, 12:50:44 PM »
Really quite Beautiful Mike!
