Author Topic: WNW Albatros D.V/Albatros D.Va Triple - and one more Jasta14 Albatros D.II  (Read 69315 times)
Offline Umlaufmotor
The upper wing sits on the struts and is also glued in place.
The bracing of the Albatros - except for the undercarriage - is also already around the corner.
It's always nice to see how the self-made turnbuckles - due to the thin wire used in the brass tube - align themselves in the direction of the tensile force.
Servus
Bertl
Offline Umlaufmotor
The elevator control cables are also already fixed in place.
Servus
Bertl
Offline Umlaufmotor
All control surfaces are deflected according to the stick and rudder bar position.
Servus
Bertl
Offline Umlaufmotor
In retrospect, I'm glad that I spent a lot more time on the model than I had originally planned after picking it up again years later.
However, some cosmetic improvements (also in the cockpit) are still necessary.
But that's at the very end.
Now to build the undercarriage.
This was already finished as a separate component, but the Zentrale Abnahmekommission (ZAK) (or in English Central Acceptance Commission) refused to give me the stamp for the successful load test over 40Kg .......... briefly, I accidentally stepped on it with my foot  ::)
That's all for now.
Servus
Bertl
Stunning work Bertl, this is an absolute gem all round. And I am glad you will overcome the issues with the underside crosses and the clumsy treatment of your undercarriage!
Offline Richtrad
Bertl, you have Superman eyeballs and an incredibly steady hand to pull off the tiny incredible details. This Albatros is really really something.
Warren Q
Offline AngryJazz
    • @AngryJazz_Models
Wow incredible work!  ;D
//Ben - @AngryJazz_Models
Offline Jorgo
Absolutely stunning work, Bertl ! Congrats !
Greetings
Joerg
That is an absolutely Gorgeous Albatros! The rigging is perfect. Looking forward to the next post!
Offline Umlaufmotor
Hi Nigel,
yes, the problem with the iron crosses incorrectly underlaid in the white rectangle has been repaired.
The undercarriage has also been completely rebuilt.
This built of the Roden Albatros D.I is nearing completion.
Servus
Bertl
Offline Umlaufmotor
Warren Q
Thank you very much Warren.
Well, I'm sure I missed and/or didn't show some interesting details.
But this time I'm quite happy with the result so far.
Servus
Bertl
Offline Umlaufmotor
Vielen Dank @AngryJazz  ;D
Servus
Bertl
Offline Umlaufmotor
Greetings
Joerg
Vielen herzlichen Dank, Joerg  ;)
Thank you very much, Joerg  ;)
Servus
Bertl
Offline Umlaufmotor
Thank you very much, Rick.
Yes, this time I'm quite happy with the result so far.
Now the undercarriage and a few other little things and this Roden Albatros D.I is finished.
Servus
Bertl
Offline Umlaufmotor
Moving on - there is not much left to do on the model.
Now to the undercarriage.
This is the second version, unfortunately there are no photos of the first one - but in retrospect it doesn't matter anyway as I accidentally crushed it  >:(
The rear strut leg was hollowed out with a 0.5mm drill to a depth of 11mm.
A 0.5mm thick brass rod was inserted into this deep hole and bent at the protruding end at the correct angle - strut to fuselage.
A number of smaller indentations can also be seen on the strut shafts - these were drilled with a 0.3mm drill.
Here a strut leg is attached to the model to check the correct alignment.
This alignment was simply done by eye, I didn't measure or anything.
Servus
Bertl
« Last Edit: April 03, 2025, 03:45:41 AM by Umlaufmotor »
