Author Topic: WNW Albatros D.V/Albatros D.Va Triple - and one more Jasta14 Albatros D.II  (Read 69313 times)
Superb, absolutely superb. Thanks again for sharing your step by step photos, these will be so helpful for my future Albatros builds.
Amazing craftsmanship!  A pleasure seeing these builds come to life.
Offline Jorgo
Excellent, Bertl ! I'm beginning to run out of words to express my admiration for your great work
Greetings
Joerg
Offline Allan31
Amazing....just...amazing.....
Offline Umlaufmotor
@andonio, Zac, Nigel, Tim, Joerg and Allan
Thank you very much for your kind comments.
Servus
Bertl
Offline Umlaufmotor
At the moment I've lost a little of my enthusiasm for model building, so I've only done a few small jobs on the Albatros D.I
The windshield is a kit part from the WingnutWings Albatros D.V/D.Va.
Of course it had to be adapted to the Albatros D.I compared to the rounder fuselage contour of the D.V.
But that was no great problem.
As the material thickness of the windshield straight out of the box is far too thick,
more than half of it was scraped off the back of the disk with a sharp scalpel blade.
The screw heads on the lower part of the windshield were marked with a 0.2 mm drill bit.
Then made transparent again with fine sandpaper and polishing paste.
The oil marks were made with heavily diluted dark brown oil colorant.
This was then sealed with Tamiya Smoke mixed with a drop of matt clear lacquer. Also on the back of the windshield to filter the strong shine of the transparent plastic.
The rudder was given some minor ageing, weathering etc. with pastel.
Servus
Bertl
Offline Umlaufmotor
The exhaust has now also been completed.
I have already described the painting technique in a post here in the thread, everything is quick and easy, really no witchcraft.
In the pictures, the exhaust was not yet glued to the model.
That's it again.
Servus
Bertl
Incredible detail & paintwork Bertl.
Very nice details! Truly inspirational.
Offline Umlaufmotor
Thanks Gary and Andreas!
Servus
Bertl
Offline Umlaufmotor
The windshield is now fixed to the Albatros model.
Positioned with white wood glue and then firmly attached with superglue.
The wing root fairings are also ready to try on the model. Let's see how exactly they fit or whether they "need to be carved".
Servus
Bertl
Offline Allan31
I keep finding wing root fairings in metal.
Now that's sad news, I can guarantee we have not lost enthusiasm for following your amazing builds. And it does seem like you are still making good progress, these recent updates are as amazing as always.
Offline Flamingo
Probably there were both!
wood  more wood
Greetings Joachim
jets are for kids
Offline Umlaufmotor
Thank you, Allan, Nigel and Joachim  ;D
Yes, apparently there were actually both variants of the wing root fairings - sheet metal, painted or, in the case of Oeffag, very often bare, as well as plywood.
For the D.I and D.II series types - as far as I have found pictures - probably only plywood.
Also on the Albatros D.III partly plywood, partly sheet metal.
However, it is sometimes difficult to make a 100% assessment of the black and white photos when the distance to the aircraft is greater.
However, a visual color match between the gray-green painted maintenance flaps and ventilation slots and the wing fairing can also help in making a decision.
Of course, original close-up photos on which the wood grain is clearly recognizable are great - but such (original) pictures of the D.I/D.II are hard to find.
Here are three D.I examples:
And here are two Albatros D.II, the first by Wilhelm Leusch
And the second one here is the D.II by Rudolf Berthold
Here as an example the Albatros D.I D.435/16 where the fuselage is painted with camouflage.
Although I am sure that the wing panels were also made of plywood, it is not really possible to tell from the picture.
Were the wing cowlings painted over because they were made of wood like the fuselage, or were they made of sheet metal and the mechanic just painted over them in his zeal?
Interesting but on this picture the axial propeller still with the early logo, the dagger, instead of the later white and circular logo with the black ?A? (WNW says that the round Axial logo was rather pale gold instead of white).
Servus
Bertl
