Author Topic: 1:32nd scale Junkers J.1  (Read 12361 times)
Offline rhwinter
Re: 1:32nd scale Junkers J.1
« Reply #30 on: July 21, 2022, 06:24:45 PM »
LIKE!
« Reply #31 on: July 22, 2022, 04:12:43 AM »
The hinged engine access doors had more detail than provided on the basic doors that are supplied in the kit.
Also Wingnut Wings chose to have four bracing ribs moulded onto the inside of both panels.
However, The only photographs of these panels, either at the time or museum aircraft, don't show four bracing ribs.
They seem to have been located on the doors as either:
        Two ribs - front and forward
   Three ribs - forward, centre and rear
   Two ribs - forward and centre.
Also there are details that needed to be added:
       Lightening holes in the bracing ribs
   Retaining cable or rod
   Additional bracing tubes
    Ports from the external cooling air louvres (right door only)
   Access panels to the engine (left door).
I opted for the three ribs (forward, centre and rear) as shown below.
The ribs were cut from 0.5 mm thick styrene sheet and drilled using 0.6, 0.8, 1.0 and 1.2 mm diameter drills.
The bracing tubes are flattened 0.7 mm diameter Brass tube.
Cooling ports and access panels were cut from 0.2 mm thick styrene sheet.
Now onto the locking plates for the two access panels.
« Reply #32 on: July 22, 2022, 06:55:52 AM »
The locking plates for the two access panels.
« Reply #33 on: July 22, 2022, 08:12:41 AM »
Those ribs are a great improvement, nice work Mike.
« Reply #34 on: July 22, 2022, 05:14:56 PM »
Very nice extra detailing!
/F
« Reply #35 on: July 24, 2022, 11:43:43 PM »
Very nice additions!
« Reply #36 on: July 25, 2022, 07:45:19 AM »
As usual your additions are awesome Mike!
« Reply #37 on: July 26, 2022, 06:24:19 PM »
All of the parts have now been painted.
I've replaced the Parabellum machine gun with a 'GasPatch' Parabellum LMG14, which only meant a slight modification to the lit supplied mounting.
Now onto applying the decals and then weathering, before construction of the model,
« Reply #38 on: July 26, 2022, 09:07:57 PM »
Very nice progress
Offline rhwinter
« Reply #39 on: July 26, 2022, 10:33:17 PM »
Looking goood! I like the hue of the green colour!
« Reply #40 on: July 26, 2022, 11:34:34 PM »
Just plain 'Tamiya' Dark Green 2 (RAF) - XF81,
« Reply #41 on: July 28, 2022, 03:32:32 AM »
A few updates.
The 'Aviattic' 5 colour faded lozenge decal applied.
Also the kit supplied decals.
I had to print the serial number for this particular aircraft.
I've fitted the tail plane, fin and rudder.
Also the two flare racks, engine Tachometer and pilots mirror.
Now it's weathering before assembly,
« Reply #42 on: July 28, 2022, 05:29:12 AM »
I've represented the front and rear grills of the radiator in the upper wing.
Cut strips of the 'RB Productions' Radiator Mesh (RB-T027), sadly no longer available.
« Reply #43 on: July 28, 2022, 07:13:31 AM »
The addition of the fabric really makes this pop. Nice work Mike.
Offline rhwinter
« Reply #44 on: July 28, 2022, 05:53:04 PM »
Beautiful - what more can I say?!
