Author Topic: 1:32nd scale Junkers J.1  (Read 12392 times)
Re: 1:32nd scale Junkers J.1
« Reply #15 on: July 12, 2022, 01:29:42 AM »
The engine is as complete as I can get it.
I've added some details:
Ignition leads support tubes
Ignition leads
Valve gear push rods
Cylinder fuel primers
Float chamber fuel supply
Magneto spark advance rod
Throttle control rod
Carburettor interconnection rod and levers
Rear engine pipes and tachometer drive.
Coolant pipe through cylinder bases
Coolant supply pipe from water pump.
The engine controls will be attached to the fuselage/cockpit later in the build.
Now onto the fuselage,
« Reply #16 on: July 12, 2022, 01:45:35 AM »
Come on Mike, do you still keep that old engine at home to take photographs ?
:-O
« Reply #17 on: July 12, 2022, 03:17:34 AM »
...I've added some details...
Your modesty is admirable Mike, but I think this is an award winning model in itself!  :o
« Reply #18 on: July 12, 2022, 03:31:41 AM »
Very nice engine!
Offline Brad Cancian
    • Brad's Models
« Reply #19 on: July 12, 2022, 07:06:52 AM »
Lovely engine there Mike, top notch.
BC
« Reply #20 on: July 12, 2022, 07:34:25 AM »
BC
YEP!
« Reply #21 on: July 12, 2022, 08:58:45 AM »
Missed the start of this. Glad I caught up. The motor details and your explanations are extremely useful. Great stuff!!
« Reply #22 on: July 12, 2022, 09:03:17 AM »
Words fail me. Truly inspirational work, Mike!
« Reply #23 on: July 12, 2022, 03:03:49 PM »
Love it Mike !
Online Jorgo
« Reply #24 on: July 12, 2022, 03:49:24 PM »
Excellent work !
Jörg
« Reply #25 on: July 12, 2022, 09:22:44 PM »
Spectacular upgrade of that Benz! And a great reference for possible future builds. Thanks, Mike.
Offline Stuart Malone
« Reply #26 on: July 13, 2022, 01:56:33 AM »
Mike,
Beautiful Benz.  I am going to do a second 1/72 J.I.  I'm definitely going to install a full engine and try to trick it out like yours as much as my abilities will allow.  Thanks for sharing the detail shots.
Stuart
« Reply #27 on: July 20, 2022, 03:02:02 AM »
The basic fuselage internals are done.
Although no rigging is necessary I have added the rudder and elevator control lines.
I've also added extra fuel pipes to the main fuel tank and the 'Telefunken' wireless aerial wire, wrapped around the spool on the set in the gunners cockpit.
Finally the two filler caps on the right side forward from the pilots cockpit - I assume these were for fuel and coolant.
I've not fitted the two aileron control rods from the cockpit as they can be easily broken during subsequent handling.
I've tested and they can be fitted later but before the engine is finally fitted.
The engine shot below is test fitted only.
« Reply #28 on: July 20, 2022, 09:38:35 AM »
Wow!! Big jump forward. That looks awesome.
« Reply #29 on: July 21, 2022, 08:40:31 AM »
Gorgeous paint work Mike!
