Author Topic: 1/28 drawings for Fokker Dr.I prop?  (Read 2842 times)
« on: May 20, 2022, 05:39:30 PM »
I’ve got a Revell 1/28 Dr.I that really deserves a proper propeller and I’d like to try my hand at making one. The only thing is, I’ve no idea where to find a suitable drawing or template to use.
Can you help?
Re: 1/28 drawings for Fokker Dr.I prop?
« Reply #1 on: May 20, 2022, 06:42:46 PM »
Zac, here are the plans
http://www.holzpropeller.de/index_english.htm
As not all links work here is the drawing alone, which I also used for my 1/8 AXIAL air screw.
Just print it out in the needed size. To help with interpretation of the lines I included tho photo page.
May be here are also useful pictures:
https://www.facebook.com/DIYAXIAL
Good luck and show your result please!
« Reply #2 on: May 20, 2022, 09:49:27 PM »
I typically use a kit prop of the correct type as a model, or look a photos and drawings and just shape it.  Drawings can help get the overall shape right, but the airfoil and angle on the blades is just guess work.
« Reply #3 on: May 21, 2022, 07:50:57 AM »
Thank you very much, Frank!
You just reminded me I was recently gifted a Roden Triplane (thank you again - you know who you are!) so I'll see how I go using that as a pattern...
« Reply #4 on: May 24, 2022, 02:21:15 AM »
Thanks for posting the drawing, Frank.
One can see there are 7 layers with the dark layer on top and bottom.
Online DaddyO
« Reply #5 on: May 24, 2022, 04:06:16 AM »
Probably not so important for our static models, but the angle on the blade is actually determined by the shape of the prop block.  :)
So if you have a plan and side view you will have enough to get accurate pitch or blade angle along the blade.(Done by shaping plan view first then side view and then carving diagonally from one edge to the opposite. Most blades have finer pitch towards the tip which is automatically incorporated by the taper on the block)
 If you have the wish you can use maths to alter the pitch distribution within the overall block dimensions by carving.
(Attached is a picture of yours truly flying a small vintage coupe model with a single bladed carved propeller at a comp which google have cropped nicely, but if you click on the image you can see the model and prop)  :-[
