Author Topic: Morane-Saulnier Type "N", Special Hobby 1/32  (Read 63202 times)
Offline Umlaufmotor
Re: Morane-Saulnier Type "N", Special Hobby 1/32
« Reply #90 on: May 09, 2022, 02:07:31 AM »
An aluminum tube was glued to the end of the fuselage to provide sufficient stability for the rudder.
Servus
Bertl
Offline Umlaufmotor
« Reply #91 on: May 09, 2022, 02:14:28 AM »
First test:
Rudder is movable.
Offline Umlaufmotor
« Reply #92 on: May 09, 2022, 02:21:35 AM »
Photo-etched parts are included with the model to represent the rudder horns.
However, these were too unstable, too flat and unsuitable for my project.
Do-it-yourself was the motto.
The rudder horns were carved from scrap plastic.
The challenge is to make both horns look exactly the same and to keep the scale effect.
Servus
Bertl
Offline Umlaufmotor
« Reply #93 on: May 09, 2022, 02:26:26 AM »
And now the next test:
Note the rudder at the end of the fuselage and the position of the rudder bar in the cockpit.
It works   ;)
« Reply #94 on: May 09, 2022, 02:31:06 AM »
I was waiting for this, to see the working rudder. Will you do this for the elevator, too?
« Reply #95 on: May 09, 2022, 02:54:27 AM »
Magical work, Bertl  :o
Pure magic.
« Reply #96 on: May 09, 2022, 03:00:22 AM »
What a great detailing!
Incredible job on the prop and the spinner to begin with.
The miniscule scratched turnbuckles and control cables are awesome.
And a working rudder and elevators is just genius Bertl!
Slicing up such a tiny engine and rebuilding it is very courageous but it turned out very well.
Your detailed build log is a feast to follow!
Offline Umlaufmotor
« Reply #97 on: May 09, 2022, 03:29:33 AM »
@PrzemoL
Yes, the elevator are also movable.
I'll get to that for tomorrow with the next set of pictures .
It wasn't quite as easy as with the rudder, but in the end it works very well  ;)
The model itself is now almost finished, the only thing missing at the moment is the mounting of the wings to the fuselage.
Otherwise everything is finished except for a few small things.
@bobs_buckles
Thanks Bob, but that's just the little wizardry .... I learned that in Gryffindor  ;D
@Rookie
Thank you very much for your kind words, Willem.
It goes even further with the built log, the next challenge was the scratch built of the interior of the cockpit.
Unfortunately, very little is included in the box.
Servus
Bertl
« Last Edit: May 09, 2022, 03:47:21 AM by Umlaufmotor »
« Reply #98 on: May 09, 2022, 07:06:16 AM »
Bertl, the word I keep coming back to describe your work on this N is "exquisite". Truly exquisite craftsmanship.
« Reply #99 on: May 11, 2022, 04:10:25 AM »
Incredible, magical and a bit of Stardust, Bertl! This is a very inspiring thread to follow! Well done! Marc.
« Reply #100 on: May 12, 2022, 03:47:02 AM »
Catching up after being away for a few days. This is scratch building at a level that only Frank and a few others can match. Brilliant.
Offline AlbertD
« Reply #101 on: May 12, 2022, 02:38:07 PM »
Absolutely beautiful work. Thank you for sharing it.
« Reply #102 on: May 13, 2022, 07:23:56 PM »
@PrzemoL
Servus
Bertl
I am eagerly looking forward to see it complete. Your attitude to the modeling and the results are... I ran out of appropriate words...
« Reply #103 on: May 13, 2022, 10:15:52 PM »
Amazing miniature engineering!!
Offline Umlaufmotor
« Reply #104 on: May 15, 2022, 01:30:42 AM »
Well, after a very tedious and busy week I only manage to post pictures again today.
But that's life..... .
But first, thank you all for your kind words, I'm glad if you enjoy the build report.
Servus
Bertl
