Author Topic: Morane-Saulnier Type "N", Special Hobby 1/32  (Read 63175 times)
Offline Umlaufmotor
Re: Morane-Saulnier Type "N", Special Hobby 1/32
« Reply #195 on: May 24, 2022, 05:06:39 AM »
The oil pump with the connection for the oil line was made of Evergreen plastic.
Likewise the ignition distributor.
All lines and pipe connections were represented either with copper wire or solder wire.
Servus
Bertl
Offline Umlaufmotor
« Reply #196 on: May 24, 2022, 05:08:44 AM »
First primer, then Mr. Metalcolor "Stainless
Offline Umlaufmotor
« Reply #197 on: May 24, 2022, 05:10:49 AM »
Now the details were painted.
Servus
Bertl
Offline Umlaufmotor
« Reply #198 on: May 24, 2022, 05:13:18 AM »
First oil traces were represented with Tamiya "Smoke".
Servus
Bertl
Offline Umlaufmotor
« Reply #199 on: May 24, 2022, 05:14:50 AM »
The next step was a washing with dark brown, very diluted oil paint.
Servus
Bertl
Offline Umlaufmotor
« Reply #200 on: May 24, 2022, 05:20:02 AM »
Finally, the entire front fire wall was covered with heavy oil spills.
Don't forget, Rotary engines are very dirty cronies.
Here is the intake and carburetor installation mounted to the front firewall.
That's it for today, see you soon.
(@Zac, I try to delay the next picture posting a little bit)
Servus
Bertl
« Reply #201 on: May 24, 2022, 07:38:14 AM »
Awesome stuff !
« Reply #202 on: May 24, 2022, 05:08:22 PM »
This build report should be printed and published as a book. i‘d buy it (even as an untranslated Bavarian original  ;))
« Reply #203 on: May 24, 2022, 05:44:04 PM »
I totally agree!
« Reply #204 on: May 24, 2022, 05:58:55 PM »
Bertl, this level of detail is just outstanding. I do hope you are going to leave some panels off so this fantastic work can be seen. It would be such a pity to hide it away inside.
« Reply #205 on: May 24, 2022, 09:28:22 PM »
Amazing work, Bertl.
As Sandy says, I hope you can find a way to make the detail visible.
« Reply #206 on: May 25, 2022, 04:34:38 AM »
« Reply #207 on: May 25, 2022, 07:30:12 AM »
I thought it was safe to go back onto the forums... ;) ;D My goodness Bertl, your extra work on this is nothing short of incredible!!
I wholeheartedly agree.
« Reply #208 on: May 25, 2022, 08:50:26 PM »
Amazing miniature engineering followed by incredible paint and weathering!!
« Reply #209 on: May 29, 2022, 01:00:03 AM »
Yep!
