Author Topic: Queen of the Pfalz  (Read 13875 times)
Re: Queen of the Pfalz
« Reply #60 on: May 14, 2025, 05:58:05 PM »
Nice. Do not stop  ;)
« Reply #61 on: May 16, 2025, 03:37:41 PM »
That is coming together really nicely.
« Reply #62 on: May 16, 2025, 04:16:59 PM »
Excellent work, A. Love the idea of attaching spokes to the inside wheel covers - why hadn't I thought of that before?
Please do get her to the finish line.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #63 on: May 19, 2025, 09:43:09 PM »
Very nice work - coming along beautifully :)
//Ben - @AngryJazz_Models
« Reply #64 on: May 19, 2025, 09:56:33 PM »
Thank so much guys for the comments , glad that you are enjoying the build just as much as I'm .
Warren Q , I think what helped was the amount of sanding and not having the cowl side panels off . I'm sure of it now . It is a tight fit , the frame work isn't glued in place .
yes adding the spokes brings a bit more detail into an empty place , it's not perfect for it does the trick . On the Part PE set there are spoke wheels but i never found this to be realistic being flat , maybe for another project in the future .
Progress has been moving forward for the build , was able to get a bit of time at the bench with a few more items off the list . Details added .....
Tail skid pinned for added strength
Bolt heads added to the rudder hinges
Taping added to the fusleage seems ( bottom runs form nose to tail )
I added a lip for the cowl panels to attach to , these panels over lap so not fully correct but does add to the over all effect . I don't have the cowl panels parts anymore so I just winged it with a bit of gizomology .
Retaining chips on the front cowl
moisture drain holes on the bottom of the fuselage , one just behind the wing root and the other one is in front of the tail skid .
Vale springs with PE parts for the PE set for the spring tops . Still have the rocker arms to add
Bolt heads added to the rocker covers
Seat belt bolt heads added to the fuselage sides .
All struts are pinned
Guns
Rad stutter
And that is where I'm at now with the build .
« Reply #65 on: May 19, 2025, 09:57:09 PM »
« Reply #66 on: May 19, 2025, 09:57:49 PM »
« Reply #67 on: May 19, 2025, 09:58:42 PM »
« Reply #68 on: May 19, 2025, 09:59:19 PM »
« Reply #69 on: May 19, 2025, 09:59:55 PM »
« Reply #70 on: May 19, 2025, 10:15:11 PM »
Very nice. You have a sharp eye for the details.
« Reply #71 on: May 20, 2025, 01:24:33 AM »
A very nice leap back into it!
« Reply #72 on: May 20, 2025, 03:29:49 PM »
Thanks Borsos and Steve
« Reply #73 on: May 20, 2025, 05:56:48 PM »
Wow, superb detail work. The cabane struts are particularly impressive. This is going to be great!
« Reply #74 on: May 20, 2025, 06:07:43 PM »
Indeed, a great datialing work all around.
