Author Topic: 1:32nd scale RAF BE2c  (Read 37259 times)
Re: 1:32nd scale RAF BE2c
« Reply #75 on: May 26, 2022, 08:24:34 PM »
Some really lovely decal work, there, Mike! I'm enjoying this thread! Regards, Marc
« Reply #76 on: May 27, 2022, 04:57:02 AM »
Well it happens  >:(
I accidentally spilled a bottle of White Spirits over my modelling workspace and, unfortunately the model.
I tried to dab it off but it had already dissolved areas of the applied decals on all of the models parts.
As I had no CDL decal replacements and no wanting to purchase and wait for replacements, I decide to go to Plan B.
This required the removal of as much of the decal as possible, leaving some in place as weathering effect.
The fuselage took the main hit, but fortunately not inside the fuselage.
So I've stripped all of the decals (CDL, roundels and black stripes).
The black stripes were airbrushed and replacement roundels and 'lift here' decals were applied.
My plan is to apply 'Flory Models' Dark Dirt and Grime fine clay wash (which I normally apply anyway).
Hopefully the wash will compliment the residual CDL decal to give the model a well worn, war weary look.
We'll see,
« Reply #77 on: May 27, 2022, 05:15:48 AM »
Mike, I'm really sorry to hear that!
But you are not alone: I once managed to knock over a bottle of Tamiya Extra Thin >:( That dissolves everything that stands in the way ...
Good luck with fixing the damage!
« Reply #78 on: May 27, 2022, 05:17:10 AM »
Ouch! These things happen! I know you will persevere, Mike!
« Reply #79 on: May 27, 2022, 07:36:16 AM »
Oh dear, Mike!! I'm confident you can recover from this with an even better model!
« Reply #80 on: May 27, 2022, 05:30:58 PM »
Ouch! That hurts just reading about it Mike...
I had a similar mishap a while ago with Tamaya Extra Thin, but the only casualty was my cutting mat. I could save my work with a quick wipe.
I am confident that a man with your skills and experience can turn disaster into fortune though and make it look even better than intended!
Looking forward to the pictures of her resurection.
« Reply #81 on: May 29, 2022, 12:49:14 AM »
Having had to recover from Numerous disasters I feel your pain! I am sure you will make this one a winner like all of your Models!
« Reply #82 on: May 30, 2022, 09:00:55 PM »
PLAN B.
Damaged CDL decal, fuselage decals removed.
Black squadron stripes airbrushed, fuselage and 'Lift Here' decals replaced.
'Flory Models' Dark Dirt and Grime clay washes applied.
Sealed with 'Alclad' Light Sheen (ALC-311) clear lacquer.
Hopefully a more dirty, 'war weary' finish.
« Reply #83 on: May 30, 2022, 09:49:03 PM »
Nice save!! I've never tried the Alclad clear. Might give it a shot - looks good.
« Reply #84 on: May 30, 2022, 10:15:16 PM »
Excellent recovery Mike. Looks better than My painting without a Spill to repair !
« Reply #85 on: May 31, 2022, 01:52:03 AM »
Hi Steve,
I always use that lacquer for final finish and sealing.
Many have problems with Alclad's not drying fully and still being tacky to the touch way after other paints would be fully dry.
I've found this to be true in some cases, but airbrushing in light coats and allowing them to dry between coats is the way to go.
I also wear lint free cotton or nitril surgical type gloves when handling Alclad treated parts.
That way you won't have any direct finger to paint contact and with no heat, no tackyness,
« Reply #86 on: May 31, 2022, 05:35:08 AM »
The kit supplies a photo-etch carrier for three spare ammunition drums for the Lewis machine guns.
Various profiles and photographs show these carriers to have storage for different amounts of ammunition drums.
The photograph below show a captured No.13 Squadron BE2c with a four drum carrier, as does the colour profile I'm using for this model.
Therefore I chose to make this type of carrier from 0.2 mm thick plastic card.
This was primed white then airbrushed with 'Tamiya' Dark Yellow (XF60).
I then brushed Windsor and Newton Raw Sienna (Griffin Alykld).
The four ammunition drums are those from the replacement 'GasPatch' Lewis Mk.1 stripped half heatsinks (32-32052) set.
They were airbrushed with 'Tamiya' Gloss Black (X1), then with 'Alclad' Steel (ALC-112).
The rounds were brushed painted with 'Mr. Colour' Brass (219) with 'AK Interactive' Brown Leather (AK3031) for the hand straps.
« Reply #87 on: May 31, 2022, 05:42:11 AM »
Following your build with great interest!
« Reply #88 on: May 31, 2022, 08:01:28 AM »
That worked out perfectly!!
« Reply #89 on: May 31, 2022, 09:56:54 AM »
Mike,
       So sorry to hear of your mishap, I've had a few lately myself, but luckily for me I was able to save model bits and pieces from my own ham-fistedness. What a beautiful save you made of it though.
This build continues to inspire.
WD
