Author Topic: 1:32nd scale Fokker D.VI  (Read 19921 times)
Offline rhwinter
Re: 1:32nd scale Fokker D.VI
« Reply #30 on: March 31, 2022, 05:18:00 PM »
Simply WOW! Such beautiful work!!
Offline Dirigible-Al
« Reply #31 on: March 31, 2022, 06:04:27 PM »
I agree, great work on the guns and the interior.
Alan.
« Reply #32 on: March 31, 2022, 08:15:31 PM »
Wow - masterful work thus far
« Reply #33 on: March 31, 2022, 08:19:48 PM »
Your usual elegant, neat and clean work. I am watching with pleasure and interest.
« Reply #34 on: April 01, 2022, 01:08:03 AM »
Your DVI is really looking great Mike !
« Reply #35 on: April 01, 2022, 06:05:22 AM »
Apart from the cockpit surround padding, windscreen, Fokker type panel fasteners and weathering, the forward fuselage is done.
Both machine guns with feed and ejection chutes.
Photo-etch ammunition belts.
Photo-etch blast plates.
Expended rounds counter decal.
Panel between gun breech blocks (omitted from kit),
« Last Edit: April 01, 2022, 08:17:15 PM by Mike 'Sandbagger' Norris »
« Reply #36 on: April 01, 2022, 06:44:42 AM »
Congratulations Mike, the whole area looks superb. Great work!
Offline ondra
« Reply #37 on: April 01, 2022, 06:10:48 PM »
Brilliant work so far, Mike, I will be following with great interest!
Ondra
« Reply #38 on: April 01, 2022, 11:42:33 PM »
The additions and upgrades look great Mike!
« Reply #39 on: April 02, 2022, 08:06:53 AM »
All of the parts have now been primed with white, polished then gloss clear coated.
White because the 'Aviattic' lozenge decals are 'clear' backed, meaning the base colour will show through to give the linen effect.
« Last Edit: April 02, 2022, 10:05:32 PM by Mike 'Sandbagger' Norris »
« Reply #40 on: April 02, 2022, 11:54:10 AM »
excellent progress Mike. Looking forward to seeing this one covered in Lozenge!
« Reply #41 on: April 02, 2022, 07:44:23 PM »
Looking nice and clean as ever Mike. Great progress and beautifully detailed!
« Reply #42 on: April 05, 2022, 06:58:03 AM »
Just a quick update.
I'm working through applying the lozenge decals to the model.
Upper surfaces are the 'Aviattic' 4 colour faded (ATT32008) and undersides (ATT32010).
The border and rib tapes are cut from ATT32069 for upper surfaces and ATT32071 for the undersides.
The main lozenge decals were cut out and applied over a white gloss base coat to allow the linen effect to show through.
The border and rib tape decals are white backed and applied onto the main decals.
Fokker ignored the specifications of the ‘Idflieg’.
Instead using their standard method of covering the wings, with the lozenge pattern applied horizontally across the top and underside of the wings and the fuselage, with wing border and wing rib tapes of the same pattern.
For the ailerons, the elevator, tail plane and the fuselage sides, the lozenge pattern was applied vertically (front to rear and top to bottom).
Each wing rib was taped but border tape was only applied to the trailing edges of the lower wing and upper wing, across the centre section between the inboard aileron edges.
I still have the border tapes and underside rib tapes to apply,
Offline Beto
« Reply #43 on: April 05, 2022, 07:28:54 AM »
The lozenge looks great, Mike! - But... are you sure about the lozenge covered undercarriage wing? As fas as I know it was painted green on the Fokker Dr.I, D.VII and E.V, so probably the same applies to the D.VI
« Reply #44 on: April 05, 2022, 07:50:29 AM »
Nice work on the decaling Mike
