Author Topic: MENG 1/32 Fokker DR1  (Read 11332 times)
Offline Grant
« on: February 20, 2022, 12:06:15 PM »
Starting my first build in almost 20 years, have a lot to relearn but looking forward to the challenge.
The first build for my workshop will be the new MENG Fokker DR1, which will representing the Red Barron's last aircraft, seemed like a good place to start.
Picked up some study material and a few addons to play with, this should be a pretty fun build.
I decided I wanted to enhance the canvas seat backing unit by adding actual lacing and brass tubing to it. I messed up the original kit piece, so I was forced to scratch build it, this was actual a lot of fun creating it. Here is the final result with the lacing and brass tubing added, turned out ok I guess, could have done better but need to hone my skills a bit. This was my first attempt at working with oil paints for adding depth and weathering, lots to learn in how to apply these oils so you can get that realistic effect that so many on here do to perfection.
Starting to work on the cockpit frames.
« Last Edit: June 07, 2022, 11:43:03 AM by Grant »
Offline Europapete
Re: MENG 1/32 Fokker DR1
« Reply #1 on: February 20, 2022, 01:01:04 PM »
That's a great start Grant! Very well done. You have chosen a good kit to start off with and a very good reference. My one suggestion at this point would be to use a finer thread material next time. Awesome that you could scratch build another part this early in your hobby, your skills will build fast. Regards, Pete in RI
« Reply #2 on: February 21, 2022, 04:34:04 AM »
I don't know what has happened to the photos but they all say unavailable in a black box?
« Reply #3 on: February 21, 2022, 04:53:35 AM »
Once the photo situation is shorted , will be following alone Grant .
Alexis , fingers crossed !
« Reply #4 on: February 21, 2022, 10:56:21 AM »
Hi Grant
Can you advise what the situation is re the missing photos? Is this just a glitch or have they been removed?
I'm sure many of us wanted to see how your Meng Dr.1 build goes so hopefully the absent images issue can be fixed soon.
cheers
Offline Grant
« Reply #5 on: February 22, 2022, 08:20:32 AM »
Sorry about the missing photos, I some how deleted them but they are back up now.
Not sure what I did but I'm all squared now!
« Last Edit: February 22, 2022, 08:28:25 AM by Grant »
« Reply #6 on: February 22, 2022, 09:14:22 AM »
Great to be able to see the Photos Grant! You have made an excellent beginning. I am looking forward to your progress as this is one of My favorite Aircraft and the kit is Excellent!
Offline Grant
« Reply #7 on: February 22, 2022, 09:34:16 AM »
Thank you RAGIII
The kit is very well done, hope to work on more this week.
Offline Grant
« Reply #8 on: February 22, 2022, 02:17:43 PM »
Europapete,
I decided to redo the lacing around the seat as I agree, the lacing is to thick. I used fishing line on my first attempt, is there a better material to us for this? Any suggestions would be much appreciated.
Thanks!
Offline Beto
« Reply #9 on: February 22, 2022, 09:45:42 PM »
Europapete,
Thanks!
Either thinner fishing line or, even better, heat stretched sprue. Hair from one of these cheap wigs also works...
Offline Grant
« Reply #10 on: February 23, 2022, 01:39:32 AM »
I've been looking into polyester threads as they come in many colors and thickness.
All give it a try and see how they work.
« Reply #11 on: February 23, 2022, 10:38:57 PM »
I use polyester sewing thread for this kind of job.  I dip it in watered down aliphatic glue to prevent it from fuzzing up and it holds its shape when dry.
Offline Grant
« Reply #12 on: February 24, 2022, 12:48:45 AM »
I remembered this method last night and it worked out good. Thank you for the information as that is exactly what I did. After 20 years away from the hobby there is a lot to relearn.
Offline Grant
« Reply #13 on: March 18, 2022, 02:02:02 PM »
Have not posted in sometime on my progress as I have been reading and practicing building techniques more then building!
I did finally manage to make some progress on the DR1 with cockpit detail, should pull this all together tomorrow night.
Once the cockpit is in place I will glue the fuselage together and then move onto the motor detail.
« Last Edit: June 07, 2022, 11:44:12 AM by Grant »
« Reply #14 on: March 18, 2022, 08:29:11 PM »
Sharp detail work!
