Author Topic: MENG 1/32 Fokker DR1  (Read 11320 times)
Offline Grant
Re: MENG 1/32 Fokker DR1
« Reply #60 on: April 13, 2022, 01:49:01 AM »
Thanks Gary,
Have been so busy at work I haven't had a chance yet to give it a try. I hope to test the method on some parts tonight, will post pictures of the results.
« Reply #61 on: April 13, 2022, 04:01:30 AM »
I for one am intrigued to see the effect on the model.
« Reply #62 on: April 16, 2022, 09:10:57 PM »
Is it to soon to ask about the results ?
Offline Grant
« Reply #63 on: April 17, 2022, 01:15:17 AM »
I'm hoping to give it a shot today, just have had no bench time at all. I will post my results tonight, really want to try an wrap up the DR1 soon so I can move on to another build.
« Last Edit: April 17, 2022, 10:47:33 AM by Grant »
Offline Grant
« Reply #64 on: April 17, 2022, 12:14:23 PM »
Finally had a few hours to work on the DR1 and try this crazy fabric texture idea.
I made a wood frame to attach the fabric to and will use binder clips to hold it in place instead of gluing it.
The wood frame is adjustable in 1" increments so I can adjust the size if needed.
All parts were painted with Tamiya flat red prior to applying the black fabric paint.
I'm going to use black to represent the fabric as it shows up pretty good and then once it's all clear coated and detailed it should look about right for the scale. Overall, I'm happy with the results, when you view the parts normally they look very convincing, the pictures up close make it look over powering but it really is not at all.
Glad I gave it a try.
I cut a piece of the fabric and laid it out flat making note which way the grain fabric grain is running.
After attaching it to the wood frame with the clamps I used my heat gun to tighten up the material
I placed foam down first, then laid the rudder on this to help push the part up into the fabric weave.
Then I sprayed one side and let it dry a few seconds before removing the fabric to prevent smearing the black paint.
Its pretty easy to push an form the fabric around the part.
Here some pics of the other DR1 parts painted with the black fabric added.
« Last Edit: June 07, 2022, 07:17:52 AM by Grant »
« Reply #65 on: April 18, 2022, 05:05:24 AM »
I do Like the results of your experiment! Looking awesome.
« Reply #66 on: April 18, 2022, 06:02:42 AM »
It's an ingenious idea Grant. I have my own personal reservations about "fabric effect" as you need to get very close to the real deal to see anything like it, but I hope it works out for you  :)
Offline Grant
« Reply #67 on: June 07, 2022, 11:53:41 AM »
Haven't posted in a long time as work has been insanely busy but I am making some progress on the DR1. Have not added any weathering as of yet, that will be my final step and I'm almost there!
« Reply #68 on: June 08, 2022, 04:03:26 AM »
And very well done!
Bob  ;)
« Reply #69 on: June 09, 2022, 11:45:28 PM »
Beautiful Triplane Grant!
« Reply #70 on: June 10, 2022, 01:20:28 AM »
Nice work!!
« Reply #71 on: June 10, 2022, 02:58:13 AM »
Looking really great! Well done! Marc.
Offline Grant
« Reply #72 on: June 10, 2022, 10:30:18 PM »
Thanks guys, much appreciated. After being away from the hobby so long, it's definitely been a steep learning curve.
I'm making a display case for it now and hope to button this project up in a week or two.
