Author Topic: WnW 1/32 Albatros B.II finished  (Read 27905 times)
Re: WnW 1/32 Albatros B.II
« Reply #45 on: December 20, 2021, 01:01:04 AM »
Interesting technique - but it surely works!
« Reply #46 on: December 20, 2021, 04:04:22 AM »
Very fine wood technique.
Offline Von Salza
« Reply #47 on: December 20, 2021, 07:53:39 AM »
How long are You waiting until You start to streak the paint?
« Reply #48 on: December 20, 2021, 11:21:32 AM »
You ask a good question - and it depends on how thinned the paint is. But I've learned over practice to smear it on, then wait about 3 minutes...then work the lines in. Going over it a few times....adding more paint sometimes...keep working it until all appears right. Sometimes a brush mark or smudge will render the whole thing useless. I use old oil paint that has very little "oil" left in it which helps drying time. Plus adding mineral spirits helps get rid of the oil too.
Offline Von Salza
« Reply #49 on: December 20, 2021, 10:53:42 PM »
Thank You Gary.
« Reply #50 on: December 21, 2021, 09:49:03 AM »
The wood grain effect looks beautiful to me. Excellent results.
« Reply #51 on: December 21, 2021, 01:34:59 PM »
You always impress me , top notch Gary .
« Reply #52 on: December 25, 2021, 07:58:05 AM »
Thanks everyone for the kind words! Progress has been made on my engine which needed those Aviattic primer cups. I had to make spark plugs from big bolts (shaved off spare AFV model parts) and thin styrene rod. I also decided after painting my intake manifold a beautiful copper colour to wrap insulation around it with Tamiya tape. Most of the period photos showed it. The ignition wires were done with 0.10" lead wire.
Primer cups from Aviattic added with spark plugs made from scraps.
« Reply #53 on: December 25, 2021, 11:05:26 AM »
Beautiful work on the engine!
« Reply #54 on: December 25, 2021, 12:53:23 PM »
Second that !
« Reply #55 on: December 26, 2021, 09:55:58 AM »
Ok I'll join the choir Gary...beautiful job of the engine!
Your modelling is truly a cut above.
« Reply #56 on: December 26, 2021, 09:39:32 PM »
Perfect subtle weathering!!
Offline Stuart Malone
« Reply #57 on: December 28, 2021, 05:57:32 AM »
Very nice Gary.  Enjoying following along with your progress.
Stuart
« Reply #58 on: December 29, 2021, 06:18:25 AM »
Lot's of engines being built around the forum and each one looking fantastic! Those primer cups really add to an otherwise superb engine.
« Reply #59 on: December 29, 2021, 06:01:07 PM »
Fantastic progress on the Albatros. I really like the engine!
