Author Topic: WnW 1/32 Albatros B.II finished  (Read 27970 times)
Offline the great waldo
Re: WnW 1/32 Albatros B.II
« Reply #30 on: December 10, 2021, 09:38:41 PM »
Hi folks, I've recently acquired some spoked wheels from Steven Robson for my WnW Albatros B.II and am therefore committed to build it. I made a start, and wanted to share a few pictures. I still need to receive some engine cylinder primer cups and CDL decals from Aviattic, but am bashing ahead with other bits and pieces. I wanted to emulate that translucent look to the underside of the upper wing, and have painted the shadows needed that will be covered by the Aviattic CDL decal eventually.
My Felixstowe will have to wait a little bit longer.
Is that Honduras or African mahogany the prop is made from ;)
Great stuff
« Reply #31 on: December 10, 2021, 11:43:52 PM »
Very nice pit!!!
« Reply #32 on: December 11, 2021, 10:02:31 AM »
That cockpit looks fantastic, Gary! There's some beautiful detail work in there.
Offline LT1962
« Reply #33 on: December 11, 2021, 10:39:32 AM »
I love the work.
One thing I found with my build of this kit. The struts are very thin and will need to be strengthened.
I built mine a couple of years ago now and it all went together very well. But now it has been sitting around for some time, almost half of the struts have bowed.
Something to consider when you start to work on the wings.
« Reply #34 on: December 11, 2021, 04:07:05 PM »
Beautiful start, all the details are outstanding.
« Reply #35 on: December 14, 2021, 08:36:09 AM »
Again - thanks to all for the encouraging words on the build so far!
I love the work.
Thanks for the heads-up. Not sure how I'd strengthen the struts, to be honest?
I did receive a mail-call today and can progress on the kit's engine now that I have the 1/32 scale resin primer cups from Aviattic. Here are a couple of photos with the one on the end cleaned up with a blade. They seem good in size and detail is fine.
I also closed up the back of the fuselage and the fit was quite good - very minimal gap filling with epoxy putty needed.
« Reply #36 on: December 14, 2021, 08:48:28 AM »
Looks Awesome!
« Reply #37 on: December 16, 2021, 06:22:38 AM »
Let me check...yes I have turned completely green with envy...
« Reply #38 on: December 16, 2021, 07:12:38 AM »
Excellent progress, Gary!
Really nice work.  ;)
Offline TimDEFR
« Reply #39 on: December 16, 2021, 06:55:57 PM »
Hi Gary,
Excellent work so far! How did you do those turned wires in the picture above? They look phenomenal.
Best,
Tim
« Last Edit: December 16, 2021, 07:05:54 PM by TimDEFR »
« Reply #40 on: December 16, 2021, 08:04:03 PM »
Wow!
Stunning work in the cockpit, Gary
Offline mess
« Reply #41 on: December 16, 2021, 08:14:16 PM »
Stunning work, Gary!
Martin from Czechia
« Reply #42 on: December 17, 2021, 04:35:35 AM »
Hi Gary,
Best,
Tim
Thanks Tim! If you're referring to the springs on the seat belts -  I wrapped some fine copper wire (0.010") around a 0.021" drill bit about thirty turns, then removed it from the bit. I then inserted a slightly thicker piece of copper wire (0.15") where the drill bit used to be, and bent it into a circle, cutting off the surplus. The end is covered with thin lead sheet.
The copper wire is just strands from old salvaged electrical cords.
Offline Whiteknuckles
« Reply #43 on: December 17, 2021, 08:25:32 AM »
Some lovely work on display Gary, great workmanship!
Eternal Apprentice
« Reply #44 on: December 19, 2021, 11:41:31 AM »
Thanks so much to everyone who has taken the time to comment on my build so far.
The fuselage needs to be given a wood grain finish, which is dark according to references. I'm choosing to paint my own pattern on the model, and make it slightly lighter in appearance. I've base coated the surface with a buff/flat earth mix of Tamiya paints, and gloss coated that. Over that, I've started to add a dilute oil paint mix of ochre, burnt sienna, and a touch of black, making a medium brown. Thinned with mineral spirits, the mix is being applied to separate panels with an old brush, taped off to finish a few at a time.
The mix is applied, and as it dries out, streaked in a laminar fashion to create a sort-of wood grain look. Hopefully a couple of days drying will allow me to continue more of the panels.
