Author Topic: 1:32nd scale Junkers D.I  (Read 2928 times)
« on: August 10, 2021, 04:52:16 AM »
I thought you might like to see my 1:32 scale build of a Junkers D.I from 1918.
This model depicts a Junkers D.I that was involved in a flying accident, possibly during testing, on the 3rd of October 1918.
It was most likely repaired and possibly given the Ser No: 5188/18, before being operated by either MFJG in Belgium or with Kampfgeschwader ’Sachsenburg’, operating in the Baltic during 1919.
Design:
The lineage of this aircraft traces back to Professor Hugo Junkers, when in 1912 he patented a design for a thick, cantilever constructed initially of corrugated steel.
The first Junkers J.I and J.2 monoplanes were built but proved too heavy for operational use.
Subsequently, the Junkers J.3 was redesigned during 1916 using an aluminium alloy (Duraluminium).
However, it was shelved when production was switched to the Junkers J.1 biplane, which entered service in 1917.
Due to the positive response for the J.I, work recommenced on an armoured single seat monoplane, starting with the Junkers J.5 through to the J.9, which eventually became the operational Junkers D.1.
The maiden flight took place in May 1918 and further changes to the design saw 4 aircraft of the final version dispatched to the front in October 1918.
The design of this aircraft was revolutionary for its time, a monoplane of metal construction and with only cross brace rigging on the undercarriage.
The airframe was essentially of tubular  construction with corrugated Duraluminium covering.
Various engines were fitted during the prototype stages, but it seems the Daimler-Mercedes D.IIIa (180hp) or D.IIIaü (200hp) engines were fitted to operational aircraft.
Armament consisted of twin 7.92 mm LMG 08/15 ‘Spandau’ machine guns.
Operational background:
The Junkers D.I was designated as a ‘battle plane’, meaning its perceived operational role was to be that of ground attack, rather than as a fighter.
Only 40 aircraft were built between June 1918 and February 1919 and it seems of these, only 5 were delivered to the front.
It's not certain than any of these aircraft took part in actual combat, although there were reports from the British late in the war that there were ’encounters with German monoplanes that were covered with corrugated sheet’.
These 5 aircraft were eventually abandoned on the German landing field of Hombeek in Belgium.
However, the aircraft did see active service after the war, in action against the Bolshevik forces in the Baltic countries, serving with the ‘Kampfgeschwader Sachsenburg’ volunteer regiment, commanded by Gothard Sachsenburg, a former pilot of the German naval ’Marine Jasta’.
The regiment consisted of 3 squadrons, being FA413 (reconnaissance), FA416 (fighter) and FA417 (ground attack).
Both FA416 and FA417 operated the Junkers D.I as well as the Junkers CL.I (two seat version) aircraft.
A few aircraft were lost in combat, including a Junkers D.I being flown by Josef Jacobs.
When hostilities ceased, those aircraft remaining were found by Soviet forces, abandoned on an airfield near Riga.
The model is 1:32nd scale and made by ‘Wingnut Wings’ (Kit No: 32065).
The list of changes/additions to the model are:
Engine:
Detailed with Nickel-Silver  and Brass rod or tube to replace Coolant pipes, ignition lead support tubes, sump vent pipe, induction manifold pre-heat pipes, forward air pump pipes.
Ignition leads at the Magneto’s and spark plugs are lead wire.
Spark plugs and fuel primers are from ‘Taurus Models’.
Rigging:
Rigging is 0.08 mm or 0.12 mm diameter mono-filament with ‘GasPatch’ 1:48th scale turnbuckles and 0.5 mm or 0.4 mm diameter blackened Brass tube.
Aftermarket:
‘GasPatch’ Spandau machine guns used to replace kit parts.
Pilot figure is Wings Cockpit Figures’ LSK leaning pilot (LSK 14),
Mechanic figure is ‘Copper State Models’ German ground crew (F32-012).
Propeller was the Axial wood laminated version from ‘ProperPlane’.
The forum build log is here:
https://forum.ww1aircraftmodels.com/index.php?topic=12382.0
As usual I've created a downloadable build log in Adobe PDF format, for those who might want to refer to it for reference or build details. It contains full step by step descriptions of the model build, its modifications/changes and is also supported with illustrations and photographs. If viewed in Adobe Reader, each build log has book marked chapters/headings for easier navigation through the log.
My model website has the gallery page, so to view any model, go to the gallery and select it.  If it has a PDF build log, it will be available to download using the 'PDF' icon on that model photo page. For any photograph, just click the photo to enlarge or reduce the viewing size.
http://igavh2.xara.hosting
« Last Edit: August 10, 2021, 05:13:39 AM by Mike 'Sandbagger' Norris »
Re: 1:32nd scale Junkers D.I
« Reply #1 on: August 10, 2021, 05:17:09 AM »
The metallic finish is very convincing indeed. The very slight variation in colour and tone realy captures a slightly worn look. The two figures also add realism to the scene - in all an absolutely fantastic model in every way.
« Reply #2 on: August 10, 2021, 05:30:36 AM »
Wow Mike, That was incredibly Fast! You have produced another Fantastic Model as always! Beautifully detailed and painted.
« Reply #3 on: August 10, 2021, 05:42:31 AM »
Looks amazing to my eye.
Well done!!
vB  ;)
« Reply #4 on: August 10, 2021, 06:06:44 AM »
Beautiful work, Mike. Excellent details, great paintjob, great figures.
« Reply #5 on: August 10, 2021, 07:54:02 AM »
Mike , she turned out just fabulous ! I really like how the figures are posed  :)
« Reply #6 on: August 10, 2021, 08:18:23 AM »
I have just passed through the build log and came here. Well, what can I say... Your usual spectacular detailing and amazing finish. Always a pleasure to behold.
« Reply #7 on: August 10, 2021, 11:04:49 PM »
Wonderful model and finish, Mike
« Reply #8 on: August 11, 2021, 10:01:54 PM »
The subtle shading of the metal surfaces makes an interesting visual cue.  Sharp detail all around.  The posed figures also imply motion and action going on.
« Reply #9 on: August 11, 2021, 10:45:30 PM »
    The corrugated sheet covering of the aircraft presents a very unique challenge to finish realistically and you've really accomplished a great result here Mike. Great detail, wonderful overall finish and a magnificent model overall, just a sheer pleasure to view!
Offline ModelCellar
« Reply #10 on: August 11, 2021, 11:31:26 PM »
I like it !  VERY NICE !!
« Reply #11 on: August 12, 2021, 03:37:59 PM »
Wonderful build. The engine looks very realistic in the perfect painted fuselage. The aluminum look is on point.
Bye Manni
« Reply #12 on: August 13, 2021, 10:26:49 AM »
Excellent job as always, Mike!
« Reply #13 on: August 13, 2021, 03:40:46 PM »
Beautiful and very convincing, with the usual top class finishing. Thank you for sharing.
« Reply #14 on: August 21, 2021, 08:41:50 AM »
Mike, what a beautiful Junkers!
I like the rivets in the corrugations. I guess it is a WNW feature but your paint job shows this.
The guy on the wing is in big trouble if his supervisor saw this, he should stand on the wooden running boards. ;) Yes I know, it is a problem of available figures in specific poses.
