Author Topic: 1:32nd scale Junkers D.I  (Read 7270 times)
Re: 1:32nd scale Junkers D.I
« Reply #15 on: July 29, 2021, 08:55:40 PM »
Simply stunning details Mike!
« Reply #16 on: July 31, 2021, 11:25:14 PM »
Engine done,
« Reply #17 on: August 01, 2021, 12:02:29 AM »
Crank it up and start flying!
« Reply #18 on: August 01, 2021, 06:40:07 AM »
Wow!
« Reply #19 on: August 01, 2021, 07:01:57 AM »
Beautifully done Mike  8)
« Reply #20 on: August 03, 2021, 06:24:26 AM »
The basic internal fuselage is now finished.
The model will be made with both wings attached.
I've added a spark advance control and both throttle cable and gun triggers cables.
The engine oil tank and the two machine gun need to be fitted, but only after the fuselage is closed up.
I'm replacing the kit supplied machine guns with 'GasPatch' resin weapons,
« Reply #21 on: August 03, 2021, 06:30:29 AM »
Awesome interior work as always Mike!
« Reply #22 on: August 03, 2021, 09:17:36 AM »
That's some really sharp detail, Mike.
« Reply #23 on: August 04, 2021, 05:49:34 AM »
I've closed up the fuselage now and added the Radiator assembly, tail plane and rudder.
I've also completed the weapons fit, having replaced the kit machine guns with equivalents from 'GasPatch'.
That required some heavy modifications to the gun mountings parts,
« Reply #24 on: August 05, 2021, 03:16:15 AM »
Such a great WNW kit in the hand of this artist = fantastic result!
« Reply #25 on: August 05, 2021, 09:20:48 PM »
Nice work Mike , still love the engine  :)
« Reply #26 on: August 06, 2021, 05:08:08 AM »
I've painted the airframe now.
This particular aircraft had a 'Tiger Stripe' metal panel strip finish.
This appears to have been alternate Aluminium polished and non-polished panel strips.
This was done by masking and airbrushing 'Alclad' Duraluminium and Steel.
The rudder was just primed with white.
Next is painting fuselage details before adding the landing gear etc.
« Reply #27 on: August 06, 2021, 11:13:53 PM »
The Machine Guns look great as does the painting on the wings and fuselage! Beautiful finish Mike!
Online macsporran
« Reply #28 on: August 06, 2021, 11:32:44 PM »
This is masterful. A joy to watch.
« Reply #29 on: August 09, 2021, 10:05:11 PM »
Fantastic work, Mike. Another masterpiece out of your hands.
Bye,
